Results 1 to 10 of 10
Thread: Running Pump
    Jun 2010
    Boston, MA
    4
    Running Pump
    Hello, I am new to this forum and appreciate all of the knowledge and advice that is shared here. I was wondering if somebody had a guideline for how long you should run the pump each day once the water is clear. Thanks for the help.
    ~20,000 gallon IG gunnite pool
    40 sf Anthony Apollo DE Grid Filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Running Pump
    That seems like a simple question, but one that you will get many different answers to. The shortest one is whatever is enough for your pool.
    Mar 2010
    Spring, TX
    1,082
    Re: Running Pump
    From what I have read on this forum. you need to run it enough to turn your water over twice. Basically enough to circulate your gallons through the filter twice.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: Running Pump
    There was an article in our real estate section this weekend about pools. Several builders recommended that in Texas, once the outside temp hits 90------you should run your pump 12 hours daily. I run mine 8-9 hours daily, basically any time it has sun on it. No problems yet.
    Re: Running Pump
    The rule of thumb is to have a pump that is capable of doing two or three turnovers a day, and then only run it enough to do one turnover a day. A "turnover" means pumping as much water as the total amount of water in the pool. How many hours that works out to in practice varies greatly, depending on the relative size of your pool and pump.
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Re: Running Pump
    Not meaning to "jack" someone else's post, but a relevant question; how does one calculate the avg. time it takes to turn over the water in the pool? Thanks.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Jun 2010
    Sewickley, PA
    11
    Re: Running Pump
    Quote Originally Posted by Dora
    The best thing I've found so far is this:
    http://www.naturalhandyman.com/iip/i...servation.html
    Down near the bottom is a chart for gallons, pump power, and the pressure gauge on your filter.
    Pittsburgh, PA
    16000 gallon AGP, Perflex EC40C75 DE filter, 1.5 HP pump
    22,548
    Re: Running Pump
    Basically It's gallons of water in the pool divided by gallons per hour of pump flow. Since most pumps are rated in GPM just multiply that by 60 to get GPH.
    For example the pool holds 13,000 gallons and the pump flows 60gpm, the formula would be 13,000/(60*60)=3.6 hours for one turnover.
    Apr 2010
    Southern California
    83
    Re: Running Pump
    Loved that "pool conservation" link. I'll be saving that one.
    Hope the OP doen't mind if I add a question or two....
    -Should the pump typically be running when there are swimmers in the pool?
    -Should you wait one full turnover when adding chemicals (chlorine, acid, etc) before allowing swimmers into the pool?
    12,000 gallon IG (newly re-plastered) pool, Pentair 3/4hp pump, DE filter, TF-100 test kit
    Mar 2010
    Spring, TX
    1,082
    Re: Running Pump
    Quote Originally Posted by Uncle Ben
    Running the pump is just whatever your preference is. If you do not have a safe cover on your main drain then you may want to think about leaving it off. The good thing I have found is I run mine and anything that gets stirred up, gets pulled into the skimmer.
    In reference to your second questions, if I add chemicals before people are going swimming, I usually have them wait 30 minutes.
