Thread: how badly do i need CALCIUM
    hi,
    im pretty new here and im pretty new in the pool owning world.
    i've read a lot and im starting to understand more the chimistry of the pool.
    i did calculation with the pool calculator but im unshure if i used the good parameter.
    first : i tell you my actual pool reading and guessing. you have to know that i just fill the pool after painting it. At the beginning i shock for 24 hour with the chlorinator, i run the pump and chlorinator 24h a day for the last 2 week. Now i run the SWG and the pump 12h a day. the swg is at minimum and chlorine occillate between 2-4. But im limited on the real number by my test,as it read only from 0 to 3 ppm after i guess on yellow intensity.
    reading from a 15$ test kit
    CL : 3
    PH :7.5
    TA: 95
    CH: guess at 140 ( from city number)
    CYA: guess at 25 ( from pool calculator estimate using 6 lbs of isocyanuric acid)
    Salt: Guess at 4200 ( from calculator )
    1-i use a SWG. i cant figure how to consider the paint as plaster, vinyl, fiberglass?
    2-the cya is a bit low i think i will raise it slowly
    3- i wonder how badly i need more calcium to prevent corrosion.
    4-is isocyanuric acid, is it the same as cyanuric acid, does it need more?
    Actually the water is clear but at night, if i look at the underwater light, i see that the water has a haze. it might be du to the limit of filtration from sand filter. i know i put a bit too much salt, but this will go down with back wash and fill up.
    i would like to have a taylor kit but im doomed since i live in canada and they seem hard to find. There is no Us merchant that want to ship here and TF-100 can't be shipped here too. the only i saw here was 3 time the price of the same US kit.
    your advice are welcome,
    bye
    16x36 50 years old painted gunite inground
    Zodiak LM2 SWG, Jacuzzi 1HP, Sand filter
    Re: how badly do i need CALCIUM
    You need better test results than just guessing. If you really can't afford a Taylor kit, you still need something.
    If you painted everywhere below the water line and the paint is in good condition you can treat the pool as a vinyl liner pool. But if there are any leaks in the paint layer you should treat it as a plaster pool.
    Yes, isocyanuric acid is the same stuff as cyanuric acid.
    hi,
    thanks for answer. it's not really that i can afford the kit. it's just that paying 240$ for the regular k2006 seem to be a total ripoff.
    if some of your fellow american want to have a side line... buy TF 100 or k2006 and sell them on ebay for us canadian.
    i will come back with more precise result,
    bye
