Thread: Pump Leaking
    estogo's Avatar
    Jul 2009
    Houston
    34
    Pump Leaking
    Hey guys,
    I live in Texas and for a while thought my water loss was relatively normal due to intense heat and evaporation (plus I swim a lot, normal spashout). I have an irrigation system and planted a station to fill in the pool with a 1/4" drip line for about 20 minutes a day (unless it rains, then I delay the timer).
    Anyway, last night I was inspecting the equipment (really want to introduce a homemade "liquidator" type of setup) and noticed it was a little wet around the main pump. The next morning it was bone dry (pump hadn't ran all night). I ran the pump again and there was a little water building up from the pump (not sure where, must be underneath? Didn't see any visible source).
    I've had this pump for about one year and eight months (but it may have been leaking the whole time) so I'm wondering if that's normal (I don't think so).
    So my questions are...
    What are typical causes or diagnostics to determine where your pump is leaking from?
    Is some water loss from the pump normal? (don't think so)
    I can ride like this for a while (water not that pricey) but the point is I'm losing more that I should and I'm wondering if I should bother contacting the pool manufacturer (argh, Blue Haven) or just delay the normal wait for the pump to die and buy another and deal with the water loss.
    Thoughts?
    Thanks.
    - Stogo
    15,000 gallon in ground plaster with hot tub. Chlorine Pool with Ozinator. 2 Skimmers
    SmartFilter 450/550 4 cartridge filter.
    2.5 HP Emmerson Main pump
    Hayward Super Pump II 3/4 HP pump for water feature.
    Hayward Tiger Shark robotic cleaner (LOVE IT!)
    3/4 Hayward Super Pump II 3/4 booster pump for Hayward Phantom cleaner (no longer used)
    Feb 2008
    Denton, TX
    5,061
    Re: Pump Leaking
    Welcome to TFP!
    It's not normal to have water puddling on your equipment deck.
    Unless someone else can think of another way, I would probably shut the pump off and let things dry. Then, I would start the pump up again and just watch for drips. This way, you can probably tie it into a connection or something like that.
    Re: Pump Leaking
    Water can travel a long way from a leak. Check the treaded connection on the top of your pump.( the line that goes to the filter) If thats dry , its going to be in the pump. Are there any air bubbles in the pump strainer basket? Check the pump drain plug area, the pump housing for cracks. Teflon the drain plug if needed.
    Thats about all I can think of at the moment.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pump Leaking
    Welcome to TFP!!
    When the pump first fires up for the day check the underside of the pump where the motor attaches to the housing. A blown seal assembly will drip there.
    Let us know what you find.
    Luv& Luk
    -Ted
    estogo's Avatar
    Jul 2009
    Houston
    34
    Re: Pump Leaking
    Quote Originally Posted by waste
    Welcome to TFP!!
    Well it's definately leaking from where the base of the pump is attached to the slab.
    Looks like I'm going to find out how long the warranty is from Blue Haven. Pool is one year and ten months old.
    Thanks guys.
    Mar 2007
    4,160
    Re: Pump Leaking
    Why wait for those wanks?
    It'd take me longer to search for the detailed advise that's already been posted here than to actually change the seal
    OK, I understand that it's a ~newish pump and should be warrantied but, honestly - it'd take me < 15 minutes to fix this, and step by step instructions have been posted here.
    Luv& Luk
    -Ted
