Results 1 to 9 of 9
Thread: Pic's and questions
    Jun 2007
    Overland Park, Kansas
    9
    Pic's and questions
    Hello Everyone!
    I'm new to the forum and fairly new to pool ownership. We live in Kansas City, and pools are not too common here. We put in our pool in 2003, and after firing the builder, my hubby finished it. It is an inground gunite pool with waterfall, 24'x37' at the widest and approx 7' deep at the drain with 2 skimmers. It has a centurion 1 1/2 hp pump, triton II filter, pentair chlorine feeder and polaris cleaner that I run 24/7. After weeks reading so many posts here, I've got questions:
    Are you not supposed to run the equipment 24/7?
    How do I get the fine debris from the top of the water? - too small to catch it all with a pole type skimmer net. Is that what the skimmer socks are for? I do clean the skimmers and filter basket regularly as well as back wash when needed. Just hoping for some tips on that tiny debris.
    Thanks for all the help thus far!
    angie
    IG, Plaster/Gunite, 18,000 gallons, 2003 install date
    Pentair Triton II (tr100) sand filter
    Pentair IntelliFlo Variable Speed Pump
    Hayward aquarite SWG, Polaris 280 cleaner with its own pump
    waterfall feature - used on occasion. Guardex 4 in 1 test kit
    Gorgeous!!
    Yes, the socks should help clear the tiny stuff. Could you aim your returns to better direct your water toward the skimmer?
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Jun 2007
    9
    I have tried moving the returns from moving the top of the water to much deeper, have not noticed a big difference...
    Jun 2007
    9
    oops-
    Thank you for your reply and which way would you recommend?
    30,426
    MTGEGAL,
    I'll jump in...point your returns so they ripple the surface. All pointed in the same direction, they will give a clockwise or counterclockwise flow to the surface of the water and the skimmers should suck up most of the surface debris.
    (I was born in Leavenworth...just up the road from you....You're right not too many pools out there)
    Jun 2007
    9
    I'll go give it a try now. OP, KS says Thanks Dave!
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Beautfiul. You've really got a great thumb. I've added your pool to the slidesshow.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Arizona
    924
    Oh my! How colorful and beautiful!
    Your pics have just made me homesick for the midwest, where you can grow flowers in colors other than red, orange and yellow. (well we do have a few things that grow in other colors, but not much)
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Richardson, TX
    287
    Hi Angie,
    Great pool! You guys must have very green thumbs, the yard looks awesome!
    I'll speak for myself, we only run the pump, etc. about 8 to 10 hours a day in the summer (depending on the temp...just what I was told by my father-in-law who's been a pool owner for 30+ years)
    In the winter we cut it back to just a few hours a day, in Texas we keep it running and clean year round even if we can't swim in it we can enjoy the way it looks and the rest of the back yard.
    Hope this helps a little...
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
