Results 1 to 9 of 9
Thread: Thio-Trine AKA Sodium Thiosulphate AKA Hypo ppm?
    Aug 2008
    Honolulu
    429
    Question 1: Using the above product to neutralize chlorine at a rate of 1 oz for 1 ppm Cl per 10,000 gallons, how much sulphur in ppm is deposited in a 10,000 gallon pool per oz of Thio-Trine?
    Question 1: Does this have any effect on algae either good or bad, or is it neutral, using say 7 oz?
    Thanks for any help.
    10,000 gal plaster pool,3/4 hp WhisperFlo pump, Sta-Rite Great White GW9500 pool cleaner, Hayward 300 lb Sand Filter
    Use Magenta Stuff for Iron and Silica control.
    Balance: pH 7.7 Cl 7 -8 Alk 70-80 CH 325 CyA 30 in winter - 50 in summer NaCl 1010 TDS 1200
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Thio-Trine AKA Sodium Thiosulphate AKA Hypo ppm?
    It doesn't matter. Sulfur isn't a particularly critical element for algae growth. As for the amount of sulfur added, that depends on the concentration of product -- there are many different reducing reactions that can occur with thiosulfate and chlorine so I can't tell what they are assuming. Sulfur is around 32 g/mole while chlorine is in units of around 71 g/mole -- if it takes 4 sulfur for every chlorine then for each 1 ppm FC you get rid of you will have 1.8 ppm sulfur; if it takes 1 sulfur for every 2 chlorine, then for each 1 ppm FC you get rid of you will have 0.2 ppm sulfur. The former is the more likely reaction, but dosing usually assumes less thiosulfate is required.
    Aug 2008
    Honolulu
    429
    Chem Geek,
    Thank you for the quick reply.
    If I understood you correctly eliminatinating/reducing 5 ppm chlorine would create 5 x 1.8 = 9 ppm of sulfur. Is this correct.
    Aloha.
    Mar 2007
    San Rafael, CA USA
    12,082
    Worst case, yes, but the exact amount depends on which of several reactions take place.
    Aug 2008
    Honolulu
    429
    Chem Geek,
    Thank you for the clarification. So basically it seems such a little amount it has virtually no effect on anything.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Maybe the larger question here is why do you need/want to neutralize chlorine?
    It is safe to swim at any level less that shock for a given CYA. What are your numbers?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Aug 2008
    Honolulu
    429
    I was doing an AA treatment.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Ahhh..good answer...and good luck with the treatment.
    Aug 2008
    Honolulu
    429
    Thank you,
    And thank you for your concern.
    Aloha.
