Thread: Hello from VA
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Hello from VA
    Hello, new member here. I've been thinking about buying a 14x28 Rectangle in ground pool from National Pool Wholesales and that's what brought me here to this forum. Some folks on here have had good experiences as well as bad. I guess like with anything, it depends on who you talk to.
    The only thing holding me back is the actual "do it yourself" set up. I know my husband and I just don't have the time to do it. I did talk to a guy today who does concrete work and he said he and his buddy could dig the hole and the concrete work as well as installing the pool. I'm just not sure about all this since neither have physically put a pool together. I don't doubt they would do a good job with the digging, but I don't know about the rest.
    Another concern is around here when you dig, you will hit water. The guy told me he has a pump. What do you need to do if you hit water? Any insights or opinions are welcomed.
    I've also considered buying an above ground pool. They are less expensive, but it's not what I really want...BUT, I can be convinced.
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Re: Hello from VA
    Anyone know of some contractors who could install the kit without charging me an arm, leg and my first born?
