Thread: Low CH Causing Cloudiness???
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I'm having a long-term problem with cloudy water, especially noticeable in the deep end (9 feet deep). It started last season and is continuing into this year. Could a low calcium hardness value be the cause?
    Here's why I ask - In 1978, my first job out of college was managing a community pool. "Junior olympic" size (about 25m by 10m) with a 12-foot deep diving tank. I'm guessing about 150K gal. Gunite, plaster finish, about 20 years old. With balanced water, I slowly began to have a cloudiness problem. "Experts" suggested that low CH was causing calcium to leach out of that old plaster. Solution was to add calcium chloride (a lot!) and it worked overnight like a charm.
    My current numbers:
    FC - 13
    CC - .5
    pH - 7.7
    TA - 120
    CH - 120
    CYA - 90 (Yeah, it's high. That's why my FC is 13.)
    Temp - 80
    Filter runs 24/7.
    What say you experts?
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    30,420
    Re: Low CH Causing Cloudiness???
    High calcium levels can precipitate and cause cloudiness in your water but I cannot see how low CH (which you have) can do that.
    Regardless, you need to bring your CH up anyway so it .
    Nothing in your test results would indicate a cause of cloudiness with one exception.................any time a CYA value is much above 70, my antennae go up. You are doing a good job with your FC and it's obvious you understand the importance but very high CYA pools just seem to have issues.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I gotta agree with Dave...never heard of low CH causing cloudiness.
