Thread: Insulation foam
    Western Pennsylvania
    151
    Insulation foam
    Has anyone used Styrofoam sheets to lay on top of the water to insulate?
    My pool get very little sun so I heat from a heat pump, so I was thinking if these foam sheets would float and im thinking it would be easier to put on than the solar cover.
    Any thoughts?
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    22,542
    Re: Insulation foam
    I've never thought about it but I'd think the styrofoam would tend to pill and leave those in the water after a few uses.
    Re: Insulation foam
    Funny, I was thinking about this a couple of weeks ago. I saw those sheets of sytrofoam with the blue backing that are used as moisture barriers around foundations and wondering if they would work. Then we had two weeks of 97+ degree weather and I forgot all about it......
    Rhonda
    NW Tennessee
    24' Round AGP
    13,500 gallons
    1.5 hp Pentair pump w/ sand filter
    From swamp to sparkly with BBB!
    151
    Re: Insulation foam
    The type im looking at is the blue one, not the small bead type I too was thinking about the beads coming loose.
    I was thinking of 1/2 thick sheets and cutting them into "pie wedges"
    Sand filter
    Jandy gas heater
    Intermatic timer
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: Insulation foam
    Whatever works for you. I'm thinking at some point these are a hassle to store, damaged easily if banged, bumped, etc. or if a big wind comes, they lift and get airborn. But it may work out just fine. I'll stick with the cover - it's amazing the amount of heat the blanket/covers keep in.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
