Results 1 to 11 of 11
Thread: In Dire Straits with These Stains - HELP
    Jun 2010
    Rocky Mount, NC
    9
    Hi folks I'm new to the forum and am having just major problems with staining in my Splash Superpool (vinyl) - it's 8,000 gal. 13 x 21 ft. purchased in May 2001. It started as a very small area of dark dark blotches and streaks, season before last, the folks I purchased the pool from came out and put in 4-5 lbs shock, seemed to clear it up temporarily, but last year is was worse and this year it is horrid, I'm just sick! It is getting all over the walls and in the floor too. I have spent a fortune trying everything under the sun for metals, scaling, algae and metal trap filter for refill water. Finally got another company to come out and take a look at it Friday. They said it was blue-green, black algae and said Polyquat 60 WOULD get it. So yesterday morning I picked up the Polyquat 60, put in the recommended dosage after lunch and waited for my miracle, so far this morning (8 am) - NOTHING - I just want to cry. You can scrape this stuff off with your fingernail, but it will come back in a few days. Has anyone heard of 'clorine stains' - is there such a thing? I'm open for suggestions and desperately need help - It was such a beautiful - easy to care for pool for years. Thanks everybody.
    8,000 gal Splash Vinyl Pool - 13 x 21 ft - AG (IG 2 ft) - Sand Filter - Hayward Flo LX pump
    30,421
    Re: In Dire Straits with These Stains - HELP
    Hey,
    Welcome to the forum. It's a guess without test results, but almost surely you are not holding enough chlorine in your pool.
    Read ABC's of Pool Water Chemistry and "How to Shock Your Pool" up in Pool School.
    One of the principles we teach here is there are no "magic bullets" that will clear your pool. We can, with good testing and good understanding of what chlorine does for your pool, get your pool back to crystal clear. It will not happen overnight but it can be done and it can be done by getting your chemistry at the grocery store instead of the pool store.
    You have to make the comittment to learn and the commitment to understanding how important it will be to test your water.
    So, the next step you can do is to post up a good set of current test results and we'll get you started. Plan on buying a lot of Clorox and perhaps a few other things...it won't be much. Also plan on the possibility of draining some, but not all of your pool water.
    Jun 2010
    Rocky Mount, NC
    9
    Thanks duraleigh, the guy Friday said all the stats were great, unfortunately he didn't write them down for me, and he was so quick I didn't stop long enough to get the paper and pen. That's been pretty much the routine though for the water to be crystal and the readings great. I do know that part of last year and all this year it's been hard to keep the chlorine level up. I will get the readings again and post and do some reading in the Pool School and maybe things will turn around.
    Nice to be here with you guys........
    Feb 2008
    Denton, TX
    5,061
    Welcome and hello.
    A good test kit is a necessary thing. Without it, you're just guessing at things really. Consider looking at the Test Kit Comparison page for more information on what is out there.
    If you haven't already, it would be a good idea to begin reading Pool School. There is a button on the top right-hand side of every page that will take you there.
    Jun 2010
    Rocky Mount, NC
    9
    Thanks guys, I only have 3 way strips and will go out tomorrow to purchase a test kit. Like you say guessing is fruitless and costly. I will get back with you all with some good test results and see where we can go from there.
    Thanks
    Feb 2008
    Denton, TX
    5,061
    Sounds good. If you are going to buy a test kit from a storefront, just make sure that it can test for FC, CC, CYA, pH, and TA. The best chlorine test is the FAS-DPD version and not the regular DPD.
    Jun 2010
    Rocky Mount, NC
    9
    Well, looks like I'm gonna have to order a test kit. Can't believe it - no-one around here has a test kit under $100 bucks and that's considered a cheapie, and the only ones under that only check for PH and Alk.
    I'll be back guys.....when I have something to go on.
    Robina
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    That's why you have to get a test kit and test yourself. At the pool store its only about "Money for Nothing".
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    Jun 2010
    Rocky Mount, NC
    9
    I'm back and have some readings. Tot Ch = 3.0, PH = 7.6, Alk = 240, Cal Hardness = 200, Cyanuric Acid = 92. I hope someone can help me get things back on the right track and get rid of these stains. Thanks guy,
    Jun 2010
    Rocky Mount, NC
    9
    Stain Help - Here are my Readings
    Hi guys, finally I have my readings, Total CL = 3.0, PH = 7.7, Alk = 250, Cal Hardness = 200, Stabelizer/Cy Acid = 92. Still need help with those stains
    Robin
    Your CYA/stabilizer level is way too high. You should replace water to bring CYA down to around 50 or 60.
    Your TA/Alk is also way too high. Bring your PH down to around 7.2 and keep lowering it back to 7.2 until your TA level comes down.
    Are the stains rough/textured or are they smooth?
