Results 1 to 10 of 10
Thread: Testing Numbers
    Louisiana
    127
    Testing Numbers
    Just checked pool water after a hot one today and about 4 swimmers.
    Pool Water Temp = 94
    FC = 2.5
    CC = 0
    TC = 2.5
    TA = 90
    CH = 160
    CYA = 40 Need to adjust this
    PH = around 7.5
    Borates = 50
    Salt = 3400
    Calculator says CSI = -0.33
    Seems like Borates added to pool is a major help keeping PH from rising than not having it. Using a lot less MA this year.
    Any Suggestions?
    27' Radiant Metric, 17,100 gallons
    Pentair Dynamo 1.5hp 220v
    Circupool RJ45, Sand Filter, Borates
    Dolphin DX6 Robotic cleaner
    TF 100 Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Testing Numbers
    I ran the numbers, and although FC looks a hair low, it's okay for a SWG. Do you have a question, or just bragging?
    Louisiana
    127
    Re: Testing Numbers
    In no way bragging, just getting familiar to using TF100 kit and doing my own testing. Trying to learn from the pros here, which have been helping me out a lot.
    TF 100 Kit
    30,419
    Re: Testing Numbers
    kp,
    Rig yourself up an aerator (fountain) and start to cool that pool. Get that water down around 84-88 and it'll be a lot more refreshing....for most of us, anyway. Nice work on your test results.
    Louisiana
    127
    Re: Testing Numbers
    Would turning my return jet up count? Will that also raise my PH doing so?
    TF 100 Kit
    30,419
    Re: Testing Numbers
    No, your jet won't get the water into the air high enough, long enough, or in small enough droplets to cool.
    aeration will not have much effect on your pH if it's already up around 7.4 or a little higher.
    Louisiana
    127
    Re: Testing Numbers
    Will have to try that out. Can you buy something for this to work with an above ground pool?
    TF 100 Kit
    Richard320's Avatar
    Jan 2010
    18,995
    Re: Testing Numbers
    Quote Originally Posted by kpromero
    Bragging is allowed here! Nobody else understands as well as we do how much trouble it is to get your pool to the troublefree stage!
    30,419
    Re: Testing Numbers
    Yeah, I think you can buy a floating fountain.....don't know the price.
    Search "cheap pool cooler" and you will find a thread where several of us have done homemade ones....mine cost about $4.00 and an hour or so labor.
    Louisiana
    127
    Re: Testing Numbers
    thanks again all. Love this site.
    TF 100 Kit
