Results 1 to 13 of 13
Thread: Arkansas pool
    Arkansas pool
    Testing picture size
    This would be my youngest helping me get the pool started Last September
    18' x 36' saltwater inground vinyl pool
    Re: Arkansas pool
    Let the fun begin! Once we created a level area for the pool, we extended the retaining wall ($$$)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Arkansas pool
    I recommend you upload photos using Photobucket.com or similar host site. Select the 'large' size when you upload. It's free, and then you copy the IMG code and paste it in your message here.
    Then you aren't limited on your pics space/size.
    Re: Arkansas pool
    Keep in mind this is now October of 2009. We got the wall in in between monsoon rains. My intent was to have the pool installed before winter. October is typically HOT and DRY. Not this year. It rained almost every other day.
    Re: Arkansas pool
    Thanks, but I have already compressed these. Is it ok to just do it like this?
    O.K. My pool builder busted it in between rains. He was awesome to work with. He does two pools at a time and did all the work himself. Dug the hole, set the kit, laid the pool crete, and installed the liner. Everything. I am a contractor so I elected to handle the concrete and electrical.
    Sorry. I had intended to take pics through the whole process but neglected to. Fast forward to March 2010. I let the dirt settle over the winter then got back to work.
    Re: Arkansas pool
    Almost done
    Re: Arkansas pool
    Final Pictures!
    Re: Arkansas pool
    A few more
    Re: Arkansas pool
    Special thanks to:
    Trouble free pool. BBB rocks!
    Rick Seawright for doing an excellent job building my pool.
    Martin Anaya for doing an excellent job on my concrete work.
    Nathan Waters for the awesome stonework.
    A sad note about my pool builder. Rick was measuring a liner replacement and was attacked by a pit bull. It latched onto his forearm, but luckily he is a big ole cornbread eatin Arkansas boy and wrapped his legs around its neck until someone could remove it. Still, he has had two surgeries and it was his good arm. Not sure when he can spread poolkrete again.
    He is a hard worker and a good guy. Hopefully he can recover soon.
    Re: Arkansas pool
    Awesome pool. Really really nice ... love the slide!
    Sad about the the pool guy ... hopefully he'll back to 100% soon.
    Greg
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
    Casey's Avatar
    SW PA
    10,461
    Re: Arkansas pool
    Your pool is fabulous! Can you please add the specs to your siggy. I and others would like to know how big your pool is.
    Dec 2009
    Columbia, SC
    34
    Re: Arkansas pool
    very, very pretty!
    18k gallon in ground plaster with attached spa
    Pentair CCP 320 cartridge filter
    Goldline Aqua Rite SWG
    IntelliFlo VS pump
    Teledyne Laars ESC heater
    Hayward Pool Vac Ultra cleaner w/ skimmer Vac Plate and inline leaf basket
    Palm Springs, CA
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Arkansas pool
    Fabulous pool and surrounds and that slide looks like fun
    Sending our best wishes for full recovery to Rick.
    You're done SLAMing when:
