Results 1 to 8 of 8
Thread: Labeling Valves
    Jan 2008
    Northeast Florida
    161
    Labeling Valves
    My new setup has three 3-way valves. What is the traditional/or best way to label them to avoid confusion. They aren't in a line, they are at different angles and orientations so no matter how I try to label them it seems confusing. Do you label the pipe the handle tail points to as ON? Or the pipe the "off" tab points to as OFF? What about in between (balancing) positions
    For example, on the suction side, the valve looks like this --| The skimmer pipe is to the left, the pump pipe is down and the vac pipe is up. When the skimmer is selected the handle points down. When the vac is selected the handle tail points to the the right where there is no pipe to label.
    On the return side, I have two valves in series, and that is where it gets very confusing. How do you do yours?
    33' above ground pool, 52" deep, about 27500 g
    sand filter w/zeobrite
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Labeling Valves
    I prefer to label the pipes that the valve is attached to. You can also put a small arrow on the valve pointer (opposite the handle) to avoid the handle confusion.
    Mark
    Jun 2010
    Orlando
    16
    Re: Labeling Valves
    Here are some pictures of how I've labeled my valves. Sharpie used by builder wore off quick and so I bought some sheets of letters from the hardware store and they're worked great for about 8 years. Hope this helps.
    26' x 13' freeform 10K in-ground w/quartz finish, attached spa, 36" sheer descent waterfall, 2hp sta-rite pump, sta-rite S8M150 cartridge filter, 400K BTU sta-rite natural gas heater and Jandy Aqualink RS-8 controller. Sunny Orlando.
    Jan 2008
    Northeast Florida
    161
    Re: Labeling Valves
    Ah, I think it is the semantics that is getting me. I like to think of the valves in terms of which features I want to turn ON. The valves seem to be set up for you to think of them in terms of what you want to turn OFF, and assume that feature is ON in the other two positions. Don't know why I can't get my head around that.....maybe I need to go brunette.
    Thanks for the pics
    Jun 2010
    Orlando
    16
    Re: Labeling Valves
    It was a little tricky for me too at first. In the upper picture the spa jets are off and the spa return has only a small amount of water going to it (close to off), which sends most of the return water to the waterfall and pool returns, with the pool returns getting slightly more water than the waterfall. In the lower picture the main drain is completely off so that the water going to the pump is split between the pool cleaner and the skimmer, with the skimmer pulling slightly more water than the pool cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Labeling Valves
    I just wrote on the pipes with a magic marker. I only have two three-way valves. One is in, one is out. The sides are spa and pool. The handle points to whichever one I want to use. I blend them, and after some experimentation, I put yellow paint marks where I want each valve to be. One on the handle, one on the valve body. So when I use the spa, I turn both valves to spa, then start the heater. When I'm done, shut off the heater and put the valves back to the usual position. The yellow paint makes it easy to do in the dark.[attachment=0:3rce1jei]Dsc00780.jpg[/attachment:3rce1jei]
    Feb 2010
    Houston, TX
    271
    Re: Labeling Valves
    Miranda, I see pics like these on here and my head spins too. The only valves I ever use are on/off, so I've always said to myself 'I hope all these people have those things labeled!'
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Jan 2008
    Northeast Florida
    161
    Re: Labeling Valves
    COLOR CODING!!!! I CAN wrap my head around that and I have some paint markers. I think I will go with your plan, Richard.
