Horrible test results! I have 30 ppl coming tomorrow
Jun 2, 2010
157
Fort Worth, TX
It took 2 drains of 2/3rds of the pool (once Wed night & again Thur night) to bring the salt from almost 10K to 2750K ppm. It has been a long week with working and this pool situation which I blame myself for.
Taylor K 2006 kit used.
Desperate for advice here:
Salt: 2750
FC: 0
CC: 0
TC: 0
pH: 8.0 (with acid demand test showing 4 drops to 7.6)
TA: 250 ppm
CH: it took 5 drops to get the sample to turn from pink to purple (I never saw "blue" like the kit sd)
CYA: black dot never disappears
As far as the Chlorine goes: ever since we turned the power back on to the pool equipment, the Aqua Rite registers zero with the "Inspect Cell" light on. Hubby just inspected the cell 5 nights ago (& it has not been operated since) & it is clean so basically to get past this weekend & 30 people coming tomorrow for Father's Day, I cannot rely on the Aqua Rite to produce chlorine.
And not sure where to go to get the SWG inspected. Basically we will have to call the pool installer to set up an appointment for them to come out here and look at it for us. (We live so far out they try to wait until they have multiple homes in our area to come this way.) Not that I trust them, but it's not like we live in a big city w/lots of options.
THANK YOU IN ADVANCE!
Sonflower
Since you are having a party tomorrow, I would ignore the SWCG for now and manually chlorinate.
Sounds like you have no CYA or chlorine and you need both quickly. This might be a good case for some dichlor since it quickly adds FC and CYA. Of course, you can also dose with bleach and use the regular CYA, although the liquid version CYA doesn't take near as long to dissolve as the powder does.
Add whatever acid it takes to keep that pH between 7.2 and 7.8. You will have to work on getting that TA down eventually, but that can wait until after the party.
Your main thing for now in the short term is adequate chlorine and getting CYA in there.
Thank you 257WbyMag!
I am nervous now about my judgment of adding chemicals because of many past mistakes. I will get past this but I need a confirmation.
Pool calc says I need:
to correct chlorine: 124 oz of 6% bleach (96 oz jug size)
to correct pH: 48 oz of muriatic acid 20 degree baume 31.45%
to correct CYA: 80 oz (by weight) of stabilizer
:?: Do these calcs sound right?
:?: Any reason why I cannot add them all at 1 time?
It did not give me a suggestion for TA but as you say I can address TA after tomorrow.
Hi there.. lets see if we can help you out.
first, how does your water look? Other than chems being off - is it clear?
I'm getting different results for stabilizer but that's prob cuz we are using different targets...
1. correct PH first, 48 oz is correct for a target of 7.5 - add this first, wait 30 minutes and test it again.
2. Add the bleach after 15 minutes of the acid addition. You will probably need to add another jug later tonight after sunset... leave the pump running. You don't want to add MA and bleach at the same time.
3. Add the stabilizer today, at any time it has no effect on the other chems, use the "sock method". 80 oz will get your CYA level to 40. (Once you get the SWG operational - this level should be 60-80)
Hope this helps, post back if you need anything else.
Also, i read somewhere that it was ok to put the stabilizer in pantyhose and hang in front of the jets. :?: Does that sound ok?
Now, at the risk of sounding even dumber, I gotta ask:
:?: Is there any reason why I can't put a stabilizer in front of all 4 jets at the same time?
frustratedpoolmom said:
all four jets its a great idea. leave the pump running so they dissolve quicker :)
That is a good idea. :goodjob:
Seconding FPM, I would go ahead and leave the pump running from now straight through the party.
Updated test results after adding all of the above:
FC: .5 (Note: Sample turned light purple w/2 drops of DPD Powder; & only 1 drop turned the sample colorless- sample has yet to ever turn pink like the kit says]
CC: 1.5
TC: 2.0
pH: 7.6
TA: 240
CH: 130 ppm
CYA: 50 ppm
Pool calculator says:
To correct FC: add 109 oz of bleach
To correct pH: add 13 oz muriatic acid
To correct CH: add 289 oz of calcium chloride
CYA is ok.
:?: Do those correction amounts sound right? I am not trusting myself yet, even just keying in the Pool Calculator.
:?: Any other suggestions?
A THOUSAND THANK YOUS for your time!
I know that it is less than 24 hours before your party, but I am going to have to break the news to you here.
Since your CC is > 0.5, you are going to need to shock your pool. It's got something organic in there that you need to clear. This means that you are going to have to shock your pool. This also involves not adding 109 oz of bleach (which would bring your FC up to 3.5), but adding 609 oz. of bleach, which would bring your FC up to 20.
Don't worry about the CH right now. Your pool is dirty and unfortunately, you are going to have to shock it and get rid of whatever it is in there that is making things yucky. You may be getting algae.
Please read Shocking Your Pool
to learn more about this process.
Re: Horrible test results! I have 30 ppl coming TODAY
Results after shocking:
FC: 17
CC: 0
TC: 17
pH: 8.0
TA: 310
CH: 150
CYA: 56
Salt: 2340
The only thing I can see that I need to do before the party is add 59 oz of muriatic acid to lower the pH.
This is the first time I have shocked the right way. :?: Any suggestions?
Don't trust the pH right now. Since your FC is higher than 10 ppm, it will read falsely high on the pH.
Your pH was 7.6 before you added the bleach, so it is probably okay right now. It's just reading high from the shocking part.
Water still looking good?
Ok, keep the pump running, brush a little bit, and get ready for the party.
Tonight, before you go to bed, check the FC again. Check it again in the a.m. before the sun hits the water and compare the two results. If your CC is < 0.5 and you don't lose more than 1 ppm of FC, you don't need to shock anymore. At that point, just maintain your pool with bleach until you get your SWCG back online.
Have fun today!
as far as your swg not working. I have a autopilot swg and wasn't sure it was working properly I was showing no errors. I contacted autopilot no service contractors in my area. They advised to remove the generator and place in a bucket of pool water. The unit should have a white foamy cloud coming from the generator. It makes a mess as the pump lines are open where i removed the generator and run pump and generator. I checked the bucket for chlorine before and after. My unit foamed and blew the reading thru the roof in the bucket running less than 2 minutes
