Thread: Need help identifing the connector on Smartpool Nitro cord
    The other day my Nitro Pool Cleaner would not start, so I tried to unplug it when the plug on the cord cracked apart.
    I am hoping somebody (electronic/electrical geek) can recognize the plug on the cord and the socket on the transformer. I called SmartPool and they said they can only sell me a new cord for $100+. They would not tell me what the connector brand and type is.
    Here are a couple of pictures.
    If someone can identify the connection type, brand and model then I would be able to solder one on pretty easily. Which hopefully can be done for less that $100.
    Thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Need help identifing the connector on Smartpool Nitro cord
    Send these pictures to some electronic supply places. I looked at a couple likely sources. This page has something that looks similar. Near the bottom, 86PM4
    Jul 2008
    New Jersey
    63
    I have mine in the box waiting to bring it back to Costco, it broke after the first time !! I looked to see if it had a name or part # on the plug, there is none . I would safely assume it is made in China , and you will not be able to find a replacement . I would try to call Smart Pool again, sometimes getting a different customer service Rep can lead to a different outcome, Good Luck !
    33,000 Vinyl Liner IG Pool, Hayward Sand Filter,Hayward Superflo Pump,Auto Pilot Dig 220 w/RC-52 cell, Polaris 9300xi cleaner. 4 wheel Pressure PoolCleaner.
    22,549
    I've seen that connector before. It's a standard connector. If you have time you can go to Mouser Electronics and search their catalog for circular connectors and you cna probably find it.
    the wires behind my connector on my dolphin came loose. one black wire and one white wire. Has 1 though 4 to plug each wire into...which one do they go into..thanks
    21K gal. inground with dark colored plaster, spillover spa & rock waterfall
    Jandy DE filter, Aqualink control system,
    non-SWG; switching from automatic feeder of tri-chlor pucks to manually chlorinating with bleach
