Results 1 to 7 of 7
Thread: Very high FC with 0% CC
    I'm somewhat confused this year. Last year was my first year with the pool (35,000 gal freeform vinyl). I check the levels every other day. The water was always perfect. Last years levels were:
    FC - 5 to 6
    CC - 0
    PH 7.4 to 7.6
    TA 100-110
    CH - 40
    CYA - 40
    Salt - 3200
    Salt cell set at 65%
    Pump operates 8 hrs at HS and 16 hrs a LS
    This year the pool was shocked on opening by the pool builder. However my FC is really high in the past two weeks it has gone from 8.5 to 15. The CC is still zero
    My level today is
    FC - 14
    CC - 0
    PH - 7.4
    TA - 80
    CH - 50
    CYA - 50
    Salt 3400
    Pump operates 8 hrs at HS and 16 hrs at LS
    Yesterday I reduced the salt cell to 45% and the FC droped from 15 to 14. Due to the the colder weather (high 60's to mid 70's) no one has been in the pool for the past week or so.
    Today I shut the salt cell down. (Super Chlorinate is turned "off"). I use Taylor K-2006.
    Any ideas?
    Thanks in advance
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Very high FC with 0% CC
    What's the question?
    The numbers look okay; you already turned down the SWG, so FC should drift down. Is the water cloudy or what?
    You want 0 CC.
    Richard, Thanks for the reply. The water is crystal clear. I was just concerned with the really high FC numbers compared to last year when the cell was set at 65%.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Probably just crept up a bit...colder weather...slightly more CYA and salt.
    Feb 2010
    Houston, TX
    271
    Just keep an eye on your FC level, if it stays too high, reduce your SWG % a little more until you find the right spot.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Butterfly's Avatar
    South Carolina
    10,045
    It would be helpful to responders to see your pool and equipment specs listed in your signature.
    Go to User Control Panel (top left, under TFP logo), select profile, then edit sig.
    Have you seen this Pool School article? pool-school/water_balance_saltwater_generator
    Welcome to the forum
    You're done SLAMing when:
    Jul 2007
    Rockville, CA
    99
    You have already identified the possible reason for the difference in FC levels observed from one season to the next. A reduction in bather load will place less demand on FC. You also have a slightly higher CYA level this year that is reducing loss of chlorine to the sun. I would be willing to bet that if you brought your CYA level up to the minimum suggested by the manufacturer, you would reduce chlorine demand even further and could dial down the SWG a bit more. Just a thought.
    20K inground gunite w/ Aqua Logic automation and chlorination Sta-Rite 400 K natural gas heater and cartridge filter 2 HP pump 1.5 HP spa bubbler for spillover spa 1 HP dedicated Letro Legend cleaner
    H2O: two parts Heart and one part Obsession. ~Author Unknown
