Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Pergola
    qbot's Avatar
    Jun 2010
    Central WA
    18
    Pergola
    Greetings. We have a W/SW view and get relentless sun. I was thinking a pergola off the side of the house would be just what the doctor ordered.
    Does anyone here have experience building these? I'm reasonably handy with tools but not a professional by any means. Any plans on the internets that I could crib?
    The area would be about 15' x 15'.
    Thanks for any help...
    ~23,000 gal In-Ground Gunite Pool
    Pentair Whisperflo .5 HP Pump
    Pentair Clean & Clear Cartridge (4) Filter
    Aug 2009
    Hattiesburg, MS
    84
    Re: Pergola
    Try this link. http://www.popularmechanics.com/home/ho ... la/3352816.
    My brother used it to build my parents one on their patio. He's no carpenter, but it turned out nice.
    Good luck.
    18x33 Delair Sunsation GS AGP Oval 4 shallow-6 deep mostly buried
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    143
    Re: Pergola
    I recently designed and built this. Not sure if this is at all what you are after, but since I just completed it, thought I'd share it. Sounds like you might be wanting one attached to the house though? This one is 4' x 10' at the posts, with an overall "footprint" with the overhangs of 8' x 14'. This is my first and think it turned out pretty nice.
    Chris A.
    20x40 36k gal IG vinyl pool w/diving board & slide | 1.25HP Pentair Challenger motor & pump | 30" Triton TR100 sand filter | Pentair SM-20-3 multiport | Stenner 45MHP2 Peristaltic Pump & 13 gallon carboy (BBB) | Hayward CL200 Tablet Chlorinator (rarely used now) | TF-100 | 2003 Sundance 850 Altamar hot tub
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    143
    Re: Pergola
    I just noticed you mention "Central WA" in your profile, wouldn't happen to be Wenatchee would it? If so, that's where I'm from and my folks are still there in Malaga.
    Chris A.
    Jun 2010
    San Antonio
    424
    Re: Pergola
    ChiknNutz, I am thinking of building something like you did. What size wood did you use? I need a 4 X 30 pergola and not sure how close together my posts have to be. I see you were able to use a 10 foot span.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    143
    Re: Pergola
    Since this is not a load bearing structure, it doesn't have to maintain quite the same normal building codes (unless you plan to roof it). I used 6"x6" doug fir posts and 2"x6" SPF for the horizontal beams. The corner braces, though really just intended to be decorative, are structural and do allow for a longer span so that is something for you to consider as well. However, 30' is a long span and I can't imagine being able to span much more than about 12' with a 2x6 on 16" or 24" centers. Although unnecessary for mine, I opted for 6" material strictly for looks.
    Here is a really cool site I found for inspiration: http://www.trellisstructures.com/index.html
    Chris A.
    Jun 2010
    San Antonio
    424
    Re: Pergola
    Thanks for the link. They do give me a lot of ideas. Yes, 30 feet is a long distance. Glad to learn that a 10 foot span works with a 2 X 6. I was afraid that 8 feet would be all I could do. With 10 foot spans I could do 4 sets of posts. What about a 12 foot span in the middle and then 9 foot spans on each side? Do you think I would have to go to a 2X8 for the horizontal beams?
    Larry in Texas
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    143
    Re: Pergola
    Larry, here is a decent tool to use for making some calculations. It does require some understanding of what settings to use, but fool around with it and see what you can come up with.
    http://www.awc.org/calculators/span/cal ... cstyle.asp
    Some instructions on it's use: http://www.planhelp.com/public/98.cfm
    Here is a screenshot of the settings I used based on my best guess.
    Chris A.
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    143
    Re: Pergola
    And just for good measure, one more thread I found about Pergola FAQ's. It has some good comments on rafter/lintel spacing and a link to a span table.
    http://www.popularmechanics.com/home...ergola/4294348
    Chris A.
    Jun 2010
    San Antonio
    424
    Re: Pergola
    Thanks. This is the kind of information I needed. Now I need to go find out what wood is available.
    Larry in Texas
    May 2009
    Orange County, CA
    18
    Re: Pergola
    Just wanted to add one thought. We already had a pergola but it was still really hot (backyard faces same direction as OP, but in SoCal), and the lattice work on the top only stopped so much sun. We decided to invest in a few Coolaroo Shade Sails (and I ended up throwing in a couple of outdoor fans for good measure). This is another option (I know the look isn't for everybody), however if you do the shade sale instead of the pergola it can be much cheaper
    Check out their site - some cool ideas.
    http://www.coolaroousa.com/view-prod...=Shade%20Sails
    30k gallon in ground plaster pool.
    Pentair Intelliflo VF pump running @ 25 gpm (take that Edison!).
    Broken heater from 1980 that doesn't work.
    Probably some other stuff...
    Aug 2009
    North Central Texas
    1,358
    Re: Pergola
    Quote Originally Posted by Stomp
    I really, really, really like the look of you shade sails as you have used them.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Re: Pergola
    I'm bookmarking this. It's been on my to-do list for three years but one thing after another keeps coming up.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Aug 2010
    Cincinnati, OHIO
    17
    Re: Pergola
    MENARDs (like Lowes/HD) sells a huge white vinyl one, but it's like $1700 or something crazy...
    Hydraulically mundane 20x40 rectangular polymer (~30K gal.), IntelliFlo VS+SVRS pump, IntelliChlor IC40 SWCG, Pentair CCP520 cartridge filter, LED light, 2xDeck Jets, SR Smith Turbo Twister slide
    Guest
    Re: Pergola
    This company sells them also: http://www.thenaturalhome.com/shadecloth.htm
    My house had awnings on it (pipe framing) but they don't last that long, are very expensive and require upkeep. I bought the 90% shade cloth with gromets every 12" and mounted that on the awning frame. Cost for 2 was under $200; awnings the same size would be about 10 times that. Of course, they don't block the rain like an awning would but they work for me. They'll also last many years longer than an awning. I had one at my previous house for about 6 years and it was pristine when I moved. I've had these for 3 seasons now and no problems. I put them up in April and remove in September and store them in the garage. They're much easier to install and remove than an awning also -- the former owner paid $100 or so each year for installation, and then there's cleaning for the awning also.
    BTW, at my previous house, I bought the shade from a different company and it was more expensive. I found this company when I was doing some research. At the other house, I did not have an awning frame, but had a 2nd story South-facing deck. I had pockets put in opposite ends and ran a pipe through them and mounted the shade that way. This company makes things like that too (and I thought I'd invented that idea!) :
    Open end pockets are also available, although not pictured. We fold the material over and sew an "open hem" into a side to allow insertion of a pipe or cable. Cost is the same as normal rectangle plus $1.25 per foot for the pockets. Please note that open hem pockets are simply folded over and stitched; it is not possible to create pockets with reinforced hem tape webbing.
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: Pergola
    Just thought I would share a pic of the pergola I built. It cost me less than $800 to build. I used preasure treated wood from Lowes. I had no plans and was built on the fly. It is 16' x 16'. Since this pic I have cut the top of the posts and capped them off.
    Enjoy.
    Mark
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    143
    Re: Pergola
    Here are a few more photos of the progress I've made so far.
    After erecting the pergola, I then cut out the grass to create a trench for the dirt and bark to collect. I then brought in 10 yds of dirt and moved it around by hand until I got it where I wanted it. After that, I covered the dirt with about 5 yds of tree chippings (free from the county).
    We then moved some boulders from the property. Finally, we bought some shrubs, grasses and dwarf trees to finish it off. We will likely plant a few flowers here and there too in the spring.
    Chris A.
    Guest
    Re: Pergola
    Chik, that's very attractive. What stain are you using, and are you happy with it? I have some decking to do one of these days....
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    143
    Re: Pergola
    Thx, on the Pergola I used an Olympic "toner", color was Canyon Brown from Home Depot. So far I am quite pleased with it, but only time will tell how long it lasts. If memory serves, it's supposed to be good for 5 yrs when used on fencing (i.e. vertical surfaces) and 3 yrs on decking. I chose the toner as it allows the wood grain to show thru. A semi-transparent would be similar and gives longer lifespan.
    On the fence, though, I used Olympic solid stain which is supposed to be good for like 20 or 25 years on a fence. I chose that because the fence had been stained by the previous owners and I didn't want to go thru the hassle of completely stripping the cedar to allow for the use of a semi-transparent (as I prefer wood grain to show thru if given the choice). Look at my first pix to see the fence before. This stuff really went on nice and is a lot more like paint (and is a water-based as opposed to the toner which is oil-based). I used an airless sprayer on the fence and did the whole job in about 4 hours (both sides).
    Chris A.
  20. Back To Top    #20
    Guest
    Re: Pergola
    Thanks for the info -- I'll look into color selection. I have cedar picket fencing that's 2 years old and unstained that I'd like to do with a real light color (like it looks when it's wet). The decking is old and the former owner stained it dark but that's mostly worn off although there are remnants here and there, so darker would work well there. I did some reading on stains and was sort of interested in One-time wood and Readyseal, but will look into your recommendations as well, since yours' looks so good!
    Did you rent or buy the sprayer? I have one but it's pretty small I think. I used it on my previous deck and used Behr that was just awful to work with and longevitiy was bad, but it helped sell the house so I can't really complain all that much -- just won't use that stuff again!
    Sue
