Ok, so here is an update. A couple of notes and questions first then please check my pool log for the past two weeks.
1. Sunrise and sunset are now 530am and 830pm so it's hard to get an accurate FC overnight. I'll get up before 530 in the next day or two and check it. And it's been HOT, month of June made history!!
2. I noticed that when doing the FC test sometimes the water is cloudy after putting all the drops in. It looks cloudyclear but I wasn't sure if this is what you all consider clear or if you put another drop in. It seems I always have a light pink when I add the 5 drops of the reagent to measure CC. Last night was the first time I didn't.
3. Does this normally last this long?
4. I am running out of places to brush and look for algae or organics. How can anything still be living after this long of a chlorine shock?
5. Here is a pic of a couple days ago, it still looks basically the same.
http://www.meshoxford.com/bowe/Now.JPG
Thanks to everyone!
June 21
http://www.meshoxford.com/bowe/Pool_dimensions.jpg
10:30pm - added 10 182oz jugs 6% bleach (approx 35ppm)
11:15pm - FC : 9ppm
11:30pm - added 6 182oz jugs 6% bleach (approx 21ppm)
June 22
12:00am - FC : 20ppm, CC : 4ppm
12:10am - added 4 182oz jugs 6% bleach (approx 14ppm)
1:00am - FC : 25ppm, CC : 2ppm
1:10am - added 2 182oz jugs 6% bleach (approx 7ppm)
--sleep--
7:00am - FC : 24ppm, CC : 1ppm
water looks like a beautiful electric blue and a little cloudy - this is a BIG change from before I had the TF100.
http://www.meshoxford.com/bowe/Morning_After.jpg
7:30am - added 2 182oz 6% bleach (approx 7ppm)
8:45am - FC : 32ppm, CC : 0.5ppm
12:00pm - FC : 14ppm, CC : 1.5ppm
1:00pm - added 2 182oz 6% bleach (approx 7ppm)
7:00pm - FC : 21ppm, CC : 2ppm
9:00pm - FC : 22ppm, CC : 2ppm
10:00pm - Noticed waterfall wasn't flowing too well, checked the DE psi and it was >8psi from clean start.
Backwashed and added 6lbs of DE. Now the Waterfall is flowing strong.
11:00pm - FC : 17.5ppm, CC : 1.5ppm
June 23
12:15am - FC : 18ppm, CC : 1ppm
5:30am - FC : 17ppm, CC : 1.5ppm (sunrise, pool much clearer since yesterday, still blue)
8:20am - FC : 14ppm, CC : 2ppm (pool covered in sun and close to 90F)-didn't get sample 1 foot below water level-may be off
8:30am - added 3 182oz jugs 6% bleach (approx 10ppm)
4:00pm - FC : 18ppm, CC : 1ppm
4:30pm - Tested 0 for Iron and Copper. Tested high on Phosphates, between 1000-2500
5:30pm - FC : 18ppm, CC : 1.5ppm
8:00pm - FC : 18ppm, CC : 1ppm
10:00pm - FC : 17.5ppm, CC : 1ppm
June 24
7:30am - FC : 18ppm, CC : 1ppm
12:00pm - FC : 12.5ppm, CC : 1.5ppm
4:00pm - FC : 12ppm, CC : 1.5ppm
Huge Thunderstorm
5:00pm - FC : 12ppm, CC : 1ppm
5:15pm - added 3 182oz jugs 6% bleach (approx 10ppm)
6:15pm - FC : 26ppm, CC : 1ppm
7:45pm - FC : 24ppm, CC : 0.5ppm
9:00pm - FC : 26ppm, CC : 0.5ppm
11:15pm - FC : 26ppm, CC : 1ppm
June 25
9:15am - FC : 24ppm, CC : 1ppm
10:00am - backwash
11:30am - FC : 23ppm, CC : 1ppm
6:15pm - FC : 14ppm, CC : 1ppm
7:00pm - added 3 182oz jugs 6% bleach (approx 10ppm)
9:00pm - Ran Spa mode with 2 182oz 6% bleach added in it....forgot about the spa.
maybe the spa drain has something in lines that's eating the FC?
June 26
9:00am - FC : 26ppm, CC : 1ppm
12:30pm - FC : 26ppm, CC : 0.5ppm
5:15pm - FC : 21ppm, CC : 1ppm
10:00pm - FC : 22ppm, CC : 0.5ppm
June 27
8:00am - FC : 22ppm, CC : 1.5pm
10:00pm - FC : 12ppm, CC : 1ppm
10:15pm - added 2 182oz 6% bleach (approx 7ppm)
June 28
8:00am - FC : 20ppm, CC : 1.5ppm
6:00pm - FC : 17.5ppm, CC : <1ppm
9:00pm - FC : 17.5ppm, CC : <0.5ppm
9:30pm - added 3 182oz jugs 6% bleach (approx 10ppm)
June29
8:00am - FC : 30ppm, CC : <1ppm
7:00pm - FC : 18ppm, CC : 0ppm
7:30pm - added 2 182oz jugs 6% bleach (approx 7ppm)
8:45pm - FC : 25ppm, CC : <0.5ppm
June30
8:30am - FC : 23ppm, CC : <0.5ppm
