Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: cloudy water
    cloudy water
    ok this is my first year to actually use BBB. I converted after swim season in the fall. Up until now my water has looked great. Now it is cloudy
    FC.4.2
    CC.0
    PH 7.6....thats the hardest for me to read
    TA 60
    CYA50
    1.Would the TA being low cause the pool to be cloudy?What should I bring it up too? the best I can tell is 90
    2. What other things can cause a cloudy pool?
    Deb
    27' 17,000 gal, AG,cartridge filter, 2.5 HP Waterway 2 speed
    Apr 2009
    Northeast Ohio
    221
    Re: cloudy water
    What are you using to test? Also, do you have a calcium reading? Have you added anything to the pool lately? Your FC is at the low end of what you want to maintain. You never want it below 4 with your CYA level.
    32x16 ft Grecian rectangular vinyl pool 8ft on deep end - 19000 gal. 18" Hayward S-240 sand filter. 250K BTU Pentair MasterTemp heater. Hayward 3/4 HP Super Pump.
    Re: cloudy water
    I have the TF-100 test kit. I didn't check the calcium(should I)? I added bleach last night to bring it FC6.Is it a problem that my FC dropped that much over night? I have CC reading of Zero
    Thanks
    Apr 2009
    Northeast Ohio
    221
    Re: cloudy water
    High calcium can cause cloudiness in the right conditions, probably not what's going on, but can't be sure without a reading.
    Based on your overnight loss, I'd suggest you actually do an overnight FC loss test. If you're not familiar, after the sun is off your pool, test FC and add enough chlorine to reach your target. Here's the important part: You need to test the FC again in one hour and record the result. In the morning, before the sun is on the pool you need to test FC again. If there is more than 1 ppm loss between the last nightly reading and the morning reading, you have organics in the water consuming chlorine and you need to shock.
    You may want to refer to "How to Shock Your Pool" in Pool School.
    Re: cloudy water
    ok..I'm going to shock pool tonight and do drop test. Should I adjust TA now (it's 60 and should be 90) or wait until I finish shocking?
    Thanks
    Apr 2009
    Northeast Ohio
    221
    Re: cloudy water
    If you're using liquid chlorine as your primary chlorine source and not having problems with your pH, I'm not sure you need to worry about your TA. I'm hoping other experts will give you better advice on this subject, but I wouldn't worry about that while you shock.
    Re: cloudy water
    loughps..I use the BBB system.I converted from Baqucill last Sept.I think I may have let my FC drop too much and too often.
    Apr 2009
    Northeast Ohio
    221
    Re: cloudy water
    I think you just need to shock until you pass the overnight FC test and have less than .5 ppm CC. After that's done, you can address your TA, but if it were mine, I'd just leave it there unless some of the experts come along and make a different suggestion.
    Re: cloudy water
    This cloudiness might not even be due to your chemistry, maybe it's filter related?
    None of the tests you've noted seem terribly out of line with what they should be. FC of 4.2 is more than high enough.
    I would have a look at the Calcium level if I had cloudiness that I couldn't explain. After that I would check filtration.
    Apr 2009
    Northeast Ohio
    221
    Re: cloudy water
    It could be filtering, but it seems that Debstar60 targeted FC 6 ppm last night and it was 4.2 ppm this morning. That's why I suggested doing the overnight FC loss test to make sure, but if it lost almost 2 ppm overnight, it's a sign the pool needs shocked. If the overnight test holds within 1 ppm, then a filter or calcium issue is possible.
    FWIW, I think an overnight test tonight will help lead us down the right path.
    Re: cloudy water
    If I did the Calcium test right..it is 40.Does that sound right?
    Re: cloudy water
    Sounds low... How many drops did it take to turn colors?
    Re: cloudy water
    it took 4 drops to turn it blue
    Re: cloudy water
    Assuming your water temp is about 85 F (just guessing) then your Saturation index is about -0.80 which is pretty far up on the scale as being aggressive (corrosive)
    I'm not aware of a low Calcium level causing cloudy water directly but I might focus on bringing it up some if possible.
    Your pools plaster might be dissolving before your eyes.
    Re: cloudy water
    I don't know what saturation index means.I don't have plaster...I have an AG pool.
    Re: cloudy water
    Quote Originally Posted by Debstar60
    Did not know that so, not plaster dissolving then for sure.
    I would probably super chlorinate and maybe leave your pump running overnight. See if that helps.
    22,551
    Re: cloudy water
    Hey Deb.
    Did you perform the overnight loss test yet? If so remind me what you lost.
    A CH of 40 is certainly possible. My fill water has a CH of 20. Low CH is not a problem for a vinyl pool only high CH is.
    Let's start there and work forward. We'll get this cleared up for you.
    Re: cloudy water
    Hi Bama,
    Thanks for responding. I shocked to 20. Just tested at 10:30pm and it is still 20 so I will test again in the morning.I think I just needed to shock..I haven't done it this year. But I do have another question. We are leaving Sunday going on vacation,will be gone a week. My sister is going to check on the pool (I don't want any of that other **** in my pool). Since she doesn't know how to test, what is a good guess as to how much bleach she should put it? I was thinking 182 oz every other day. Or is their a better way to tell?
    This mornings readings 6:3am
    FC16.5
    CC.5
    22,551
    Re: cloudy water
    Looks like you lost 3.5 overnight. You need to shock.
    Since you're leaving tomorrow is there anyway you can give your friend a crash course in testing just the FC using the FAS-DPD kit? If you could, she could test each evening and come here and we could tell her how much bleach to add to maintain shock till you get back. I think that would be your best bet.
  20. Back To Top    #20
    Re: cloudy water
    I brought back up to shock level this morning....will it be ok to swim in today? I will try to get her to test for me. Why did it drop but the CC is.5? Water is still a little cloudy.When I used Baq I would have been pleased for it to look like this,but I'm used to a sparkly clear pool.
    Deb
