Results 1 to 7 of 7
Thread: Filter Question
    Filter Question
    When and how long should our filter run? All day? At night?
    We have 2 speeds as well, is there a certain speed we should keep it at?
    Thanks in advance!
    Colleen
    27' Round Johnny Weissmuller Legend Above Ground Pool
    Capacity: 17,200 Gallons
    Water Depth: 44"
    Filter: Waterway Clearwater II, 150 Sq. Ft.
    Filter Type: Cartridge
    Pump: Waterway HI-FLO 48 Frame, 1.5HP, 2 Speed
    I'm chucking the pucks...heck, we never even started them, we ditched the FROG and went straight to BBB!
    22,539
    Re: Filter Question
    Since you have a 2-speed, I recommend you run it constantly on low speed except for vacuuming or anything that requires high. It'll save you a good bit on your electric usage by doing that.
    IMXTREEM2's Avatar
    Jun 2010
    Plainfield, IL
    14
    Re: Filter Question
    Is that standard practice (all the time) or do others run it only at night, only during the day, etc?
    Rich
    Water Depth: 44"
    Filter: Hayward XStream Full-Flo, 150 Sq. Ft.
    Pump: Hayward PowerFlo Matrix 1.5HP, Single Speed
    Season 3 of Jug Dumping started May 2013!
    _________________
    22,539
    Re: Filter Question
    With single speed pumps most people run them 8 to 10 hours a day. Even running a 2-speed pump on low 24 hours a day costs less than running it on high 8 to 10 hours a day. Plus running it 24 hours day provides more cleaning and prevents low spots of FC.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Filter Question
    This is really something where there is a lot of mixed thought, my personal preference is run 24x7, which should not cost too much with a 2 speed pump on low. Basically the more you run your filter the better your water will be filtered, the question is where is overkill, and in your case I suspect you have an oversized pump already, so running on high any time your not trying to clear a swamp is probably overkill. You might even get by with running it on low 12 hours per day, I think most people would say run in the day when your having chlorine loss from the sun, but since I don't deal with that having an indoor pool I am not sure.
    Ike
    Re: Filter Question
    Thanks for your thoughts everyone! I think we are gonna try to just run it about 10-12 hours a day and see how that goes for us.
    Colleen
    Water Depth: 44"
    Re: Filter Question
    I run my 2 speed on low 24/7 and I calculate I get a bit over 2 turnovers a day. So far, the water is great.
