Thread: Patching and repairing concrete for new liner
    I have some defects in the concrete floor of my pool that I need to resolve before putting in the new liner. I'd put them in these categories.
    Large dips (2 inches)
    Cracks
    Mold
    Loose concrete (thin top layer only)
    Three 1 inch holes in deep end constantly bubbling water into the pool
    I have the vinyl patching cement and sidewalk cement (without rocks). I guess I've always thought that if you are patching with cement it is important to give the new concrete some way to grip the old concrete. In this case, however, I don't think the new concrete will have anywhere to go (I've read that some people use sand) so perhaps it doesn't matter. Please take a look at the pics and tell me what you think.
    http://www.flickr.com/photos/5996555...7624174137121/
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Patching and repairing concrete for new liner
    Sorry I can't help; this is a busy time of year for our pool pros but hopefully they'll stop by to help.
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    You could ask some concrete companies. Since they pour the stuff all the time, I would think they would know the answer.
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Thank you for the pics!
    You definitely wan to patch and fill the voids and rough areas! I prefer vermiculite to sand and cement or concrete - it's softer on the liner and water can pass through it. But, you already have a 'crete' floor, so the patch doesn't really make much difference.
    Get a ~94 lb bag of Portland cement (type I or II) and a few buckets of mason's sand. Mix the cement and sand at a ratio of 2 parts cement to 1 part sand and mix it a little on the wet side, so that it feathers in better. You may need more material than I suggested, but let's start slow, rather than waste $
    Allow the patches to set for at least 12 hours, then sweep the floor at least twice before installing the new liner!
    If you need any tips on properly installing a liner, simply ask and I'll reply (Ive installed well over 1000 liners )
    Luv& Luk
    -Ted
