Thread: hawkeyes test results
    hawkeye's Avatar
    davenport,iowa
    118
    hello everyone thanks for all the help with my conversion! i have had clear water all year this year after switching from baquacil last year..here are my lastest test results from tonight when i got home from work where do i want my ch and ta levels heres my results from 10 min ago
    fc 5.0
    cc 0.0
    ph 7.9
    ch 110
    ta 130
    cya 50
    temp 82
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    Jun 2010
    Dallas Tx
    38
    Re: hawkeyes test results
    looks awesome!
    http://www.californiapoolsdirect.com serving Dallas pools since 1953!
    Dec 2009
    Central Massachusetts
    2,690
    Bring your pH down to about 7.5-7.6. It's a touch high at 7.9.
    Calcium harness is fine. You dont even need that in a vinyl pool. TA is ok. A touch high. Thats probably the reason the pH is a tad high. But dont worry about it the TA. Just get the pH down a bit with some muriatic acid. Use the pool calculator to detemine how much. Add half the amount, wait an hour and test again.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    welcome to the house!
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, what bk406 said
    Also, with CYA of 50, keep your FC between 4 and 8. You are good to go!
    You're done SLAMing when:
