Results 1 to 9 of 9
Thread: How often to check cell??
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Is there a rule of thumb on when/how often to check the SWCG cell Does the amount of calcium in the water have an affect I would think it would, but I'm still learning. I've recently bumped my CH to 275 and plan on keeping it there due to getting a few cobalt stains. What other water factors would contribute to quicker scaling
    I did a search and couldn't find an answer.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Re: How often to check cell??
    The chances of calcium scaling can be estimated by looking at the CSI. The higher your CSI, the more likely you are to have scaling. If you keep CSI slightly negative, scaling is unlikely. If you follow our recommended levels you don't normally need to worry about CSI at all, since the recommendations already take that into account. In a SWG cell adding borates lowers the chances of scaling by more than is indicated by the change in CSI, because borates reduce the amount of PH swing that occurs inside the cell.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    . If you follow our recommended levels you don't normally need to worry about CSI at all, since the recommendations already take that into account. .
    Now Jason, who else's recommendations would I follow Even before I added borates this year, my pH was generally always at 7.4-7.5.
    But, should I be checking it annually More,less
    Lynn
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Lynn I am not an expert but we only check ours when the "Inspect Cell" light on the panel comes on or we notice a decreased chlorine output. So to answer your question, we do not follow a regular schedule on that.
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Always check your cell at least once a year. If there have been calcium scaling problems in the past, or you have some other reason to suspect problems check more often.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks Jason.
    Lynn
    Jul 2007
    Brisbane, Australia
    874
    i'd say start with monthly, and if you find there is no build up - move to annually
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hi Lynn,
    Your unit will remind you to check the cell every 3 months. With it's 'autoreverse' calcium shouldn't be able to gunk things up, but it's as easy as unscrewing the 2 unions and looking into the cell to see if you have cal or debris in the cell's blades
    Luv& Luk
    -Ted
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thank you Ted
    Lynn
