Thread: Anyone ever use an air filled dome?
    mikergibson's Avatar
    Jun 2007
    Mt. Vernon, Illinois
    34
    Anyone ever have one of these air filled domes over their pool?
    http://rontimco.com/poolpg.htm
    Is it easy / cheap to heat in the winter time?
    Are they difficult to keep installed?
    Good / Bad / indifferent?
    Thanks!!
    Mike
    My Pool:
    12K gal Fiberglass. Pentair DE Filter, Aqua Logic SWG, GoldLine Controls, Kreepy Krauley pool cleaner, MiniMax 250 Heater, Pentair FiberWorks Fiber optic lighting, Pentair 1 1/2HP Pump, a new shiny TF100 test kit, a clear pool and 3 happy kids
    Arizona
    924
    I've never seen one in real life - only have seen that site.
    I wonder how noisy it is. I'd think you'd have to have the blower going all the time.
    I'm not sure that would be very pleasant to listen to day in and day out.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by Buggsw
    They are fairly quiet. It doesn't take as a big of a blower as you'd think. In colder climates, heating the pool heats the air in the dome. I have no idea how much energy you'd use heating it though. I saw one set up at a show in Atlanta a few years back.
    Sep 2007
    Gloucester County, NJ
    141
    dome
    wouldn't you still need to close the pool for the deep winter months if you tend to have cold winters with lengthy periods of below freezing temperatures? Or, if you were heating the water to 80-85 degrees consistently, does the cold temperature become a non-issue?
    28,000 gallon gunite/white plaster with 30ft RBB and 2ft sheer descent, 100 sq ft thermaledge, 50sq ft spa w/ 6 jets
    2HP Jandy pump, 60sq ft Jandy DE filter, 400,000 BTU Jandy LX Nat Gas Heater, 2 Jandy color lights + Jandy color spa light, Jandy Aqualink RS6, Jandy AquaPure 1400
    Jul 2007
    Bothell (near Seattle), WA
    46
    Requirement to close depends only on your climate and your desire to use your pool in winter (and related willingness to pay for heating). If you keep water flowing even slowly through pipes when temp is below freezing they will not freeze. If you have salt in your pool that further lowers the freezing point.
    The big issue is are you going to keep it heated enough to use in winter? If not then probably much easier to just close until climate warms up above 60 degrees F. (I read 60 degrees is a rough threshold for closing/opening. Funny thing is this summer my pool rarely got above 60 degrees !
    I live in Seattle area where we get a few weeks of freezing temperature. However it is 35-55 from October through May most years. I'm starting to look for pool domes and the bubble is a neat variation... however I need to get the deck built around the pool first so there is something to rest the structure on .
    Thanks! ZephanS
    AG 12'x24'x54" "Diamond Star" (wilbar) bought 2007 from http://www.sunenterprise.com as kit with waterco 2hp (max) pump (too big+noisy) & WaterCo T450 150lb sand filter (filled w/ 75lbs zeobrite). Pool installed 2007. 160 sq ft solar array installed (2009) on custom metal deck roof (2008). Purchase, Site prep, & installation 100% DYI thanks to PF and TFP. Wrap-around deck, small swg, electrical upgrade, and 8' water slide still pending install.
    Baton Rouge, La.
    75
    Some years ago I took scuba lessons and we started in a pool with one of these. To be honest it was kind of funky. Real wet and echoed alot. Not sure I would like it.
    Trilogy "Fiberglass" Pool,
    15x34 8900 gal.
    Pentair 1hp Super-Flo Pump
    Pentair CC100 Cartridge Filter, Pentair "Legend" Cleaner
