Thread: robotic pool cleaner question
    I got a nitro robotic pool cleaner, and noticed some old topics on it, but i didnt see one where someone had problems keeping the darn thing at the bottom and keeping it from floating to the top . does anyone that has one know how to resolve this? the manual says to clean the filter and get air out of it by moving it "side to side", which is pretty vague. dont know whether to completely submerge the thing and move it side to side or keep part of it above water and then move it side to side or what. does this happen with any other robotic cleaners and if so does anyone have any suggestions on how to solve this? Thank you in advance!
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: robotic pool cleaner question
    Well intuition says to submerge it and then move it all around to get the air out... try that?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    Maybe the impeller is jammed and creating any suction to hold it on the bottom (I think these robots have two motors, one to drive the wheels, and the other to suck up the debris).
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
