Thread: Sand in vinyl pool
    Jul 2008
    Canisteo NY
    3
    Sand in vinyl pool
    My sand filter ruptured and dumped. What is the best method to vacuum the sand(120 lbs.) from the bottom? I already replaced the sand after fixing the rupture. Should I vacuum to waste?
    24' Round above-ground
    Vinyl-1.5 hp pump
    140 lb Jacuzzi Sand Filter
    30,421
    Re: Sand in vinyl pool
    Yes. That makes good sense. In fact, I can't think of any other way to do it.
    Jul 2008
    Canisteo NY
    3
    My water is very cloudy as a result. Should I flock?
    Vinyl-1.5 hp pump
    X-PertPool's Avatar
    Exeter, PA
    1,385
    vacuum to waste, BUT be careful
    sand is very heavy!
    When vacuuming up the sand only suck up small fist sized amounts at a time and let the sand make it through your system before sucking up more. If you suck up too much sand at once your vacuum hose will sink to the bottom and you can clog the pump basket with sand. A healthy ratio of sand / water needs to be maintained.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
