Thread: Solar Cover Question...
    IMXTREEM2's Avatar
    Jun 2010
    Plainfield, IL
    14
    Guys,
    What the appropriate amount of time to have your solar cover on? Can you have it on too much? Just curios as my neighbor made a comment when I went out to check the temp and skimmer after work. She was saying you shouldn't leave it on all the time... Since we were out of town last weekend and all, it has been on since last Wednesday night (about a week now). It's coming off tomorrow to clean and swim regardless, but I was just curious overall. Thanks!
    Rich
    27' Round Johnny Weissmuller Legend Above Ground Pool
    Capacity: 17,200 Gallons
    Water Depth: 44"
    Filter: Hayward XStream Full-Flo, 150 Sq. Ft.
    Filter Type: Cartridge
    Pump: Hayward PowerFlo Matrix 1.5HP, Single Speed
    Season 3 of Jug Dumping started May 2013!
    _________________
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Solar Cover Question...
    Ask your neighbor why?...seriously...I know it can sometimes mess with PH...mine tends to drop ever so slightly with the cover on, but having it on 5-7 days is not a problem...the only thing to look out for is if you had a t-storm/wind while it is on...if there are a ton of leaves etc on top of it and it ends up in the pool, you may have to bump your FC up a bit to destroy the organics that have accumulated on top. But that all I can think of.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    There are some reports (including from myself) that leaving it on for days at a time will cause CC to creep up. Nothing to worry about, as long as it gets some open time for the sun to burn those off.
    IMXTREEM2's Avatar
    Jun 2010
    Plainfield, IL
    14
    Thanks everyone, I appreciate the feedback. Today will be our first day in - good times!
    Rich
    Water Depth: 44"
    _________________
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I leave mine on all the time. Maintain your FC levels and monitor your PH and you should be fine.
