Thread: If you use the LQ, do you use the SWG CYA/chlorine chart?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    As the title suggests, do I use the SWG chart or the non-SWG chart if I am using a LQ to determine my CYA/chlorine ratio?
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    22,548
    Re: If you use the LQ, do you use the SWG CYA/chlorine chart?
    I use the standard chlorine/CYA values. I'm not sure whether the SWCG does something extra or whether there just isn't enough data collected on the LQ to add it to the chart.
    You should use the regular (non-SWG) chart with the Liquidator. There isn't enough data to be totally sure, but so far nearly everyone who tried SWG FC levels with the Liquidator has had problems.
    flyboy320's Avatar
    Jul 2009
    216
    OK, thanks guys, I thought the SWG chart was based on the fact that the FC levels are held stable (for the most part) through the day by continuously adding chlorine to the pool, unlike the manual method of adding chlorine where it's added just once a day.
    Mar 2007
    San Rafael, CA USA
    12,082
    The SWG chart is based on observational experience. We don't really know the true reason as to why a lower chlorine level works OK for SWG pools. Some of it may be the more consistent dosing so that it doesn't get too low but some of it may be some super-chlorination of a portion of the pool water going through the cell. I suspect it's a little bit of both though more of the latter, but to play it safe we recommend the normal dosing chart. Of course, you are free to experiment with what works in your own pool and report back to us what you find.
