Results 1 to 8 of 8
Thread: Bad smell from scuppers
    We noticed a bad smell around where the scuppers shoot water out. Is there a way to fix this? It smells like a mix between rotten muddy grass and animal excretion. We don't have any pets! Please help!
    28K River Sand Plaster Finish - 2.5 HP Stealth Pump - Jandy 60 Sq Ft DE Filter - LAARS LT400 Natural Heater - Polaris 280 - Jandy PDA PS6 Computer Center
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Bad smell from scuppers
    Do you flow water through them all the time or only sometimes?
    Water flows the entire time the pump runs from 9am to 9pm. It smells really bad.
    Feb 2008
    Denton, TX
    5,061
    Is it the water that come out that smells bad or is it the area that smells bad?
    What's a scupper, if you don't mind me asking?
    Butterfly's Avatar
    South Carolina
    10,045
    Scuppers are the mouth or ledge/shelf (opening) where the water exits from a water feature.
    Posting a set of water test results and a pic of your water feature would be helpful.
    You're done SLAMing when:
    Here are my test results. Please also let me know if anything is out of balance here. Any guidance would be great! Also, a pic of the scupper as you requested.
    FC = 5.0
    CC = 0.0
    PH = 7.4
    TA = 70
    CH = 410
    CYA = 35
    Borate = 50
    30,431
    Fill a spray bottle with about 25% Clorox and water. Shut off pump and spray everywhere. Let it soak for a minute or so....scrubbing would be very help ful.
    If that doesn't clear it up after maybe three apllications or so. You'll need to get some clorox back up into the piping behind the scuppers.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I would suspect that a frog, mouse, etc. crawled back in there, died, and is stuck and stinky.
