Results 1 to 8 of 8
Thread: Cloudy Pool
    Cloudy Pool
    Help
    I have a intex above groud pool that has been cloudy from day 1 thru today or about 2 months
    The water is just now beginning to clear alittle (I can see the third rung on the ladder in the pool)
    Cyanic low and PH high/Bad combo im guessing
    what do I add as far as chemistry goes
    The pool place told me my alkalinity was to high and to add miratic acid/I did,and it lowered the alk level
    but the water is still cloudy/I feel like i am close but cant get there
    Confused
    Dave
    You should post a full set of test numbers and tell us what color/shade of cloudiness you are seeing.
    Jul 2007
    Chicago, IL
    87
    Agree .. a full set of test numbers is essential, but FWIW, I had to run my Intex pump/filter 24/7 to keep the water clear even when the water was fully balanced.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    I still have cloudy water, Intex Pool, I kept the pool at shock level for a few days, have kept it at or above 5ppm since, PH has been in range, ALK is 100, CYA is down to 20 because I drained about 1/3 of the water trying to get rid of some of the cloudy water. I have tried leaving the pump going 24/7 washing the filter out several times a day, I have tried letting everything settle and then vacuuming, and I still have cloudy water, but atleast it's sanitary, and the kids do not mind the cloudy, it just drives ME nuts.
    Fort Wayne IG Vinyl 18 x 36 (22,000 G)
    3/4 hp Pentair Pump
    Sand Filter
    Polaris 280 w/ booster pump
    No heater yet...solar cover
    Mount Airy, NC
    gonefishin's Avatar
    Joliet, Il.
    413
    Re: Cloudy Pool
    Quote Originally Posted by davidjacka
    Help
    Confused
    Dave
    Welcome to the forum
    To get a clearer picture of just what's going on with your water you really need to post a set of test numbers (FC, CC, Ph, TA, CYA etc.)
    Lowering the TA takes more than just adding muriatic acid...let us know when you get the test results
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    30,408
    David,
    To add to what Dan said, Muriatic should be used to lower pH, but not Alk. Alk can only be permanently lowered thru aeration as described in the stickies at the top of the forum index.
    Arizona
    924
    Duraleigh, aeration does not lower TA. Muriatic acid lowers TA and pH. Aeration raises the pH back up without raising the TA.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Well I did manage to clear up the water finally. With the Intex pump/filter.
    I just started leaving everything off all night every night and running the aqua critter vacuum all day every day and after about 5 days, it seems to be clear.
    I think you really wouldn't need the aqua critter if you could just rig up a way where you are sucking the water into the pump from the bottom of the pool instead of having it come in at the top.
    3/4 hp Pentair Pump
    Sand Filter
    Mount Airy, NC
