Results 1 to 8 of 8
Thread: White Stuff Info. Liquidator users please reply.
    22,553
    Trying to get some data to see if we can figure out what contributes to the formation of White Stuff.
    1. How long have you been using the LQ?
    2. List your equipment.
    1. Pump?[/*:m:1k0299su]
    2. Filter?[/*:m:1k0299su]
    3. Norm filter press?[/*:m:1k0299su]
    4. Number of skimmers?[/*:m:1k0299su]
    5. Number of returns?[/*:m:1k0299su]
    3. Do you have White Stuff?
    4. If so does it affect the performance of your LQ?
    5. How often do you have to clean it out?
    6. What parts of the unit are affected by the WS?
    1. “In” float valve?[/*:m:1k0299su]
    2. “Out” float valve?[/*:m:1k0299su]
    3. Flow meter?[/*:m:1k0299su]
    4. Flow control valve?[/*:m:1k0299su]
    5. “In check valve?[/*:m:1k0299su]
    6. “Out check valve?[/*:m:1k0299su]
    7. “In” tubing?[/*:m:1k0299su]
    8. “Out” tubing?[/*:m:1k0299su]
    7. Have you done the 3/8” tubing upgrade?
    1. “In” side only?[/*:m:1k0299su]
    2. “Out” side only?[/*:m:1k0299su]
    3. Both “In” & “Out” sides?[/*:m:1k0299su]
    4. Part of “In” side?[/*:m:1k0299su]
    5. Which parts?[/*:m:1k0299su]
    6. Part of “Out” side?[/*:m:1k0299su]
    7. Which parts?[/*:m:1k0299su]
    8. How many cc/min (number on flow meter) do you normally run?
    9. What size LQ do you have? (4 gal or 8 gal)
    10. Do you have a device that aerates the water on a regular basis? (fountain, water fall, etc.)
    11. A full set of test results?
    1. pH[/*:m:1k0299su]
    2. FC[/*:m:1k0299su]
    3. CC[/*:m:1k0299su]
    4. TA[/*:m:1k0299su]
    5. CH[/*:m:1k0299su]
    6. CYA[/*:m:1k0299su]
    7. Salt[/*:m:1k0299su]
    8. Borates[/*:m:1k0299su]
    12. Anything else you feel is pertinant to the situation.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Re: White Stuff Info. Liquidator users please reply.
    Just a question, Has anyone tried to have the white stuff tested to see what its made of? That could go a long way in discovering how and why it shows up.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    22,553
    I'll start.
    1. How long have you been using the LQ? 1 year
    2. List your equipment. 24' X 52" round AGP, Sand Filter, 1.5 hp pump.
    1. Pump? 1.5 hp Dynamo[/*:m:3f9qyvae]
    2. Filter? Pentair Sand Dollar[/*:m:3f9qyvae]
    3. Norm filter press? 11 PSI[/*:m:3f9qyvae]
    4. Number of skimmers? 1[/*:m:3f9qyvae]
    5. Number of returns? 1[/*:m:3f9qyvae]
    3. Do you have White Stuff? Yes, Slightly
    4. If so does it affect the performance of your LQ? No
    5. How often do you have to clean it out? Haven't
    6. What parts of the unit are affected by the WS? "Out" tubing only
    1. “In” float valve?[/*:m:3f9qyvae]
    2. “Out” float valve?[/*:m:3f9qyvae]
    3. Flow meter?[/*:m:3f9qyvae]
    4. Flow control valve?[/*:m:3f9qyvae]
    5. “In check valve?[/*:m:3f9qyvae]
    6. “Out check valve?[/*:m:3f9qyvae]
    7. “In” tubing?[/*:m:3f9qyvae]
    8. “Out” tubing?[/*:m:3f9qyvae]
    7. Have you done the 3/8” tubing upgrade? Yes, Both In & Out sides
    1. “In” side only?[/*:m:3f9qyvae]
    2. “Out” side only?[/*:m:3f9qyvae]
    3. Both “In” & “Out” sides?[/*:m:3f9qyvae]
    4. Part of “In” side?[/*:m:3f9qyvae]
    5. Which parts?[/*:m:3f9qyvae]
    6. Part of “Out” side?[/*:m:3f9qyvae]
    7. Which parts?[/*:m:3f9qyvae]
    8. How many cc/min (number on flow meter) do you normally run? 2.5
    9. What size LQ do you have? (4 gal or 8 gal) 8 Gallon
    10. Do you have a device that aerates the water on a regular basis? (fountain, water fall, etc.) No.
    1. pH 7.5 rock solid[/*:m:3f9qyvae]
    2. FC 5-8ppm[/*:m:3f9qyvae]
    3. CC zero[/*:m:3f9qyvae]
    4. TA 80[/*:m:3f9qyvae]
    5. CH 160[/*:m:3f9qyvae]
    6. CYA 55[/*:m:3f9qyvae]
    7. Salt none added but guessing ~ 500ppm from chlorine additions[/*:m:3f9qyvae]
    8. Borates None added but probably about 15[/*:m:3f9qyvae]
    12. Anything else you feel is pertinent to the situation.
    jwfrank's Avatar
    Oct 2008
    Todi, Umbria, Italy
    55
    I started using Liquidator last year with total success, and no WS. This year I upgraded to 3/8" line and had WS from the first fill of chlorine. i was devastated. Besides the 3/8* line, what was different? Just before the fill, I cleaned the LQ inside with vinegar, something I use to get rid of calcium build up. (The sides were "crusty" and I thought it was a calcium buildup) Vinegar worked fine and I rinsed well. But the fill of chlorine (12.5%) immediately created a ton of WS at the bottom and I had floating "flakes" throughout the water
    I let the chlorine in LQ get used up; I siphoned out all the WS at the bottom, and refilled with chlorine from a new jug. And.... no problem with WS
    Can some chlorine batches contain a "pollutant"? Was the WS a result of the residue of vinegar even though I rinsed the LQ well, I thought.
    The plastic tubes seem free of WS except AFTER the flow meter where I notice some whiteness. I notice also that the tube leading from the flow meter is half air, half water. This is strange and would indicate some air coming into flow meter from outside, but I have no leaks
    All this is submitted in answer to number 12 question: anything else pertinent
    Good luck with your investigation. (Wasnt there a long chain of info on WS from last year?)
    1. How long have you been using the LQ? 1 month
    1. Pump? 1hp Pentair Challenger
    2. Filter? Pentair Triton II 60 sand
    3. Norm filter press? 12 psi
    5. Number of returns? 3
    3. Do you have White Stuff? No
    3. Flow meter?
    5. “In check valve?
    7. “In” tubing?
    8. “Out” tubing?
    1. “In” side only?
    2. “Out” side only?
    3. Both “In” & “Out” sides? BOTH
    5. Which parts?
    7. Which parts?
    9. What size LQ do you have? (4 gal or 8 gal) 8 gal
    1. pH 7.5
    2. FC 3.0
    3. CC 0.0
    4. TA 70
    5. CH 300
    6. CYA 40
    7. Salt 0
    8. Borates 50 ppm
    13,100 gal (?) IG Plaster Pool, Rectangular (30 feet long, 11 feet wide at 3 feet deep shallow end, 14 feet wide at 6 feet deep end.)
    Pentair Challenger 1hp 2 speed hardwired pump
    Triton II T60 sand filter
    P153 Intermatic digital timer control
    8 gal Liquidator with 3/8" upgrade
    Jan 2008
    Northeast Florida
    161
    1. How long have you been using the LQ? 3 years
    Pump?Hayward Powerflo Matrix Dual Speed 1 1/2 hp pump
    Filter?, Hayward 24T sand filter w/zeolite
    Norm filter press?10-15
    Number of returns? 2
    5. How often do you have to clean it out? Once in 2 years, though not really needed
    6. What parts of the unit are affected by the WS? None
    7. Have you done the 3/8” tubing upgrade? Yes, recently, all parts
    8. How many cc/min (number on flow meter) do you normally run? 2-4, varies
    9. What size LQ do you have? 8 gal
    pH 7.5
    FC 3
    CC 0
    TA 80
    CH 50
    CYA 30
    Salt 0
    Borates 50
    I didn't have the borates the first year, but no problem with WS ever. Pool is filled with softened water (household water softener). I do have white flakes that are part of the normal sediment that forms at the bottom of the tank and can be stirred up when adding CL, but I don't consider this the dreaded WS, because I have never had any form on any of the important parts. The original tubing turned opague/white, but no deposits forming, just lost it's clarity. AFter 3 years, my parts are all still clean, though I just replaced some parts for other reasons.
    33' above ground pool, 52" deep, about 27500 g
    sand filter w/zeobrite
    Aug 2009
    North Central Texas
    1,358
    Just wondering. There is question for number of skimmers but no inquiry as to number of returns. Any reason?
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    22,553
    Good question. My thought was that turbulence or some other action of mulltiple skimmers might tend to cause the WS.
