Thread: Pin Prick Hole in Vacuum Hose
    qbot's Avatar
    Jun 2010
    Central WA
    18
    I've noticed that my vacuum hose has a tiny, almost invisible, hole in it. I can hear it hiss when I connect it to the skimmer (its right at the waterline). I'm still getting a good suction.
    Is there a product that anyone would recommend to fix it?
    ~23,000 gal In-Ground Gunite Pool
    Pentair Whisperflo .5 HP Pump
    Pentair Clean & Clear Cartridge (4) Filter
    Feb 2008
    Denton, TX
    5,061
    Re: Pin Prick Hole in Vacuum Hose
    Maybe a little epoxy would work. Of course, if this is a sectioned hose, you can just buy a new section.
    22,548
    A dab of silicone sealant shoud work, especially if you can get it into the hole.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    If all else fails, cut the end off the hose and install a replacement end.
    If you can get silicon to stay in place, try 3M 5200 adhesive/sealant. Be careful with the 5200, because it is heck to get off of anything. It's used on boats to seal screw holes etc..
    qbot's Avatar
    Jun 2010
    Central WA
    18
    Excellent suggestions. Thanks.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    polyethylene, reinforced, multi-purpose pressure sensitive tape with a soft and flexible shell and pressure sensitive adhesive. It is generally silver or black in color but many other colors have recently become available. With a standard width of 1+7⁄8 inches (48 mm).
    Duct tape.
    Works for me. I'm getting 2 extra years out of my hose...
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
