Thread: Before cutting the liner...
    At the beginning of the season, I was given a larger above ground pool. I had previously owned a 15 foot in diameter intex pool with an intex saltwater chlorinator pump combo. Since the larger pool was in fair shape, I decided to give the smaller pool, with the default pump that came with it, to a family member and use the larger pool with the saltware pump. After I had already given the smaller pool away I discovered that the larger pool was made by summer escapes. The wall fittings on the summer escape pool were not in the best of shape, and I still had the large intex side wall fittings. However, the intex wall fittings are slightly larger than the openning in the summer escape pool.
    My question is, has anyone tried cutting the liner around the wall fitting to create a larger opening for something else? Did summer escapes just cut a hole in the liner to create the opening or is there some stitching or adhesive that creates the round opening? Any suggestions on how to go about doing this without buying a new liner?
    10,000 gallons, plaster, inground, Hayward 1 HP, Hayward C1200 Cartridge, TF100
    Re: Before cutting the liner...
    Here is the link to what I am trying to install in the wall of the pool.
    http://www.amazon.com/Intex-Large-Fi.../dp/B0015QXLSQ
    Also, should this be done with or without water in the pool?
    Thanks
    22,550
    I'd just buy a standard return fitting and replace it in kind. Why take a chance on ruining the pool to save a couple of dollars. I realize you already have the fitting but if you should slip when cutting the opening larger you've just ruined your pool.
    I spoke with Genfoam and the opening is machine cut and then stitched. The return is fine, I can use the existing one. However, I have an over the wall skimmer I would like to use, and it will not adapt to the summer escape fitting.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    EVERYTHING can be adapted - you need to visit the PVC supply store. Post pix with the fittings you have.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    LOL...NWMNMom...you sound like my husband!
    27' 17,000 gal, AG,cartridge filter, 2.5 HP Waterway 2 speed
