Thread: Replastering--Too late in season?
    Aug 2009
    Hi desert,(Victorville) California
    66
    I'm considering replastering. Understanding it's almost the start of summer, I assume I won't be able to use the pool for several weeks afterwards, which doesn't bother me all that much, as summers here run well into October.
    Construction-wise, is there a general rule of thumb regarding the best time of year to do this?
    Will replastering in the summer heat have any effect on the quality of the plaster application or curing?
    Or should I wait til fall or next spring?
    Thanks for any ideas!
    P.S. I would have started this project about a month ago, but I didn't have the $$ at the time & didn't know I'd have the $$ now.
    Corey
    17,000 gal. IG pool with spillover spa, gunite/white plaster (approx15 y/o, replastered 10/2010), Filter Equipment installed 2007: Pentair CCP520 4-cartridge filter F/R 150, Pentair Mastertemp 250 Gas Heater, 3hp Pentair IntelliFlo Variable 8 Speed Inground Pump(installed 9/2011), and Proud lifetime TFP supporter!!
    Guest
    Re: Replastering--Too late in season?
    Hey Corey-I'm in "your area" and work for a plaster company (sort of!). If I was coming to your pool, I would tell you to give me a call in the fall at this point. If you can wait, wait. We plaster pools all the time at this time of the year, but you will get a better end product if you can wait until the weather cools and the plaster is not exposed to the heat.
    Now if you are considering PebbleTec or similar, that changes the response! It is much tougher than regular plaster and will take the heat much better.
    As for waiting to swim, someone is telling you a story! Once the water is in and the pool is balanced (even before, if you are careful and just can't wait to go in!) , jump in! A week at the most is all you would need to wait, and I personally think you can use it much sooner.
    PM me if you have questions and want the facts. I don't come to your area, so I have nothing to sell you! I'll just tell you the truth!
