Thread: adding a light
    May 2008
    mo kc
    11
    adding a light
    hi i have to do a liner on my 18x36 IG pool and needed to know can i add a light to the pool
    20x40 In-ground Vinyl liner with no swg yet and no heater approximatley 25000 gals
    22,550
    Re: adding a light
    You can add a light but it's a lot of work in an existing inground pool, especially if it has a concrete deck. I'm not trying to discourage you just want you to be prepared for it.
    Re: adding a light
    If you can add a 1-1/2" wall fitting and min. of 18" of conduit on the backside, you can use a savi melody light. That's probably the easiest way to go because of the small size imo. No niche or bonding required.
    15,000 gallon gunite pool, grey plaster with 8' raised spa
    Jandy PlusHP Pump 2 HP Dual Speed
    Sta-Rite 450 Sq. ft. Cartridge Filter
    Cleva-Chlor RP40HD
    Raypak 400k btu heater
    Jandy Aqualink RS-8 One Touch
    Savi Melody 12v LED lights
