Thread: Quick help on my Hayward please
    Hello, I'm draining my pool tonight due to very high CH and CYA readings and I need to know something.
    I have a vertical "pro" grid DE filter that, when clean, the individual compartments hold 6-8" of water, even after I've washed them. I'd read something about soaking them in a solution to open the pores, but I can't find it. My computer died and I'm trying to search on my phone, so if you could tell me ASAP I'd appreciate it as my pool is almost drained.
    Thank you!!
    14.5K gallon / IG / Plaster / DE filter / Learning to love pool maintenance! It's a work in progress...
    Re: Quick help on my Hayward please
    You can clean the grids extra throughly by first rinsing them off normally, then soak them overnight in a mixture of 1 cup of automatic dishwasher detergent for every 5 gallons of water, finally rinse off again. If you have a history of CH problems or see calcium scale on the girds you can follow all that with a brief soak in a mixture of one part muriatic acid to six parts water, the rinse again and re-assemble the filter.
    Thank you!
