Thread: cya question
    May 2009
    Trenton NJ
    497
    cya question
    I did the sock method and ran the filter till it was dispersed. My question is do I need to run the filter now 24/7 for a week, I was planning on running it about 16 0n 8 off, since its been on 24/7 for the past month.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: cya question
    You do not need to run the filter 24/7.
    You should wait a week before retesting for CYA because it can take a while to show up in the test.
    For the purposes of target FC level you should assume that you are already at the CYA level that you targeted.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    May 2009
    Trenton NJ
    497
    Re: cya question
    Thank you
