Results 1 to 7 of 7
Thread: My TA is dropping but the PH remains the same
    My TA has dropped from 90 to 80 but my pH has remained steady at 7.5
    Should I be trying at all to bring my TA back up to the 90-100 range or just let it be unless the pH goes down too?
    TFP SUPPORTER through TFTestKits.com - My Pool: South Florida, 11K gallons, In ground, concrete / Diamond Brite, Free Form with attached spa (no heater- go figure) Built around 1998, original surface, Jacuzzi Magnum Force 1.5HP pump, Jacuzzi Cartridge Filter, Rainbow 320 Tablet Feeder, Hayward Navigator Pro, Taylor K-2006 w/ TFTestKits replacemeng Reagents.
    30,419
    Re: My TA is dropping but the PH remains the same
    Accuracy on the TA test is +- 10ppm so let it ride until you can make an adjustment you can detect.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    TA contributes to Calcite Saturation Index (CSI) which is a measure of whether your water is likely to cause scaling, is likely to cause etching, or is balanced. TA can be adjusted to keep your CSI in range (e.g. to offset high CH)
    High TA causes upward pressure on pH. TA can be adjusted to minimize pH drift.
    To answer the question where your TA should be we need a full set of test results, but there is no reason to adjust TA just for the sake of getting it to a certain number.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    TA shouldn't drop unless you add acid. Are you using trichlor tabs? I see a tab feeder in your signature. They will slowly drop pH and TA both. As long as pH is stable, I wouldn't change your TA.
    Quote Originally Posted by svenpup
    FC - 9
    CC - .5
    PH - 7.5
    TA - 80
    CH - 260
    CYA - 75
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Are you still using tablets?
    Trichlor will constantly lower the PH a fair bit and the TA a little. Something, most likely aeration, is raising the PH back up. However aeration doesn't raise the TA, so TA will fall slowly.
