Thread: Caretaker 99 jets not rotating
    I recently bought a house which had the caretaker system already installed in the pool and i have been having nothing but problems with it so i finally had to replace the entire housing because of leaking and such but i finally thought i had solved the problems with it. While there is no more leaking only the jets in the shallow end of the pool are rotating is there anything that I can do to fix this problem without calling in the pool guy again? Thanks
    14K IG, TR-60 Sand filter, Old disintegrating plaster, & Challenger Pac-fab 1.5 hp pump
    Jul 2009
    Seattle, WA
    89
    Re: Caretaker 99 jets not rotating
    Quote Originally Posted by PhelpsJr
    I suggest you try swapping the jets from the shallow end (that you know work) with the ones that won’t spin. If they work in the deep end and the ones from the deep end still don’t work you can order replacements online.
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
    How would i swap them out do i need to drain the pool and fill it back up again?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You don't need to drain it; they unscrew with a special tool (pool store may have it). It's an under-the-water-with-goggles operation.
    Jul 2009
    Seattle, WA
    89
    I thought you only need the tool if you want to stay dry. I can get my (Masterpool) heads out by hand.
