Thread: DPD test Kit
    Apr 2009
    Raleigh, NC
    55
    DPD test Kit
    This test only reads to 3ppm of FC. If I want to test for higher levels of FC, can I simply add the water to a larger container 1:1 from the test tube and just add 3PPM each time until the color drops off? Thanks in advance.
    93mastercraft - Aqua Leader Reflexion 21' round 54" high above ground pool. This is not a $399.00 Pool! Wedding cake steps, Haywood 1.5 pump/sand filter. If I'd thought taking care of a pool was this easy, I'd owned one a long time ago!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: DPD test Kit
    No, the test drop size is calibrated to the test container size. You can dilute your pool water sample with non-chlorinated water and test the result by filling the sample tube. One part pool water to one part non-chlorinated water will test at half the actual reading etc..
    22,548
    Re: DPD test Kit
    Just go to http://www.tftestkits.net and order the stand alone FAS-DPD test kit and be done with it. You'll be much better off in the long run.
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Re: DPD test Kit
    I agree. I love my new Taylor K2006 test kit.
    http://tftestkits.net/Taylor-K-2006-p27.html
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
