Thread: jandy aqualink wiring...dog chewed wires to inside controlle
    Where can I get a piece of replacement wiring for my aqualink..its one of those wires that had three wires inside...white, red, green i think..maybe a black also?
    my **** lab got out today and chewed the wire first thing....
    built 4/08/2000 16 x32 460 Sq FT Pool 16,000 gallons 3.5 ft 5 ft 3.5 ft sport pool
    bad dog... BAD!
    sorry...
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Jul 2007
    Suwanee, GA
    528
    What gauge are the wires inside? Home Depot sells cat-3 cable which is 4 single strand copper, usually used for your phone. They may have other stuff as well, but you could always run 3 separate wires if needed. I'd just make sure they are the same or better gauge.
    I'd use one of the crimp connector where the silicone squirts out, like this:
    http://www.alliedelec.com/Search/Produc ... 00364C617F
    If you are a neat freak, then solder and use heat shrink around each wire, then heat shrink them all together. Just make sure to splice them at different lengths.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
