Results 1 to 7 of 7
Thread: shocking for first time what to expect?
    Due to fc loss overnight I will be shocking my pool. The question is what will the water do during this time? It is already clear and I could read a book that was setting in the bottom of the pool if needed. Will the shock cloud up the water?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: shocking for first time what to expect?
    What are you going to use to shock the pool?
    Bleach
    SW Indiana
    9,199
    You won't see anything but the elevated chlorine levels, assuming you don't have any metals in the water or serious other chemical imbalances.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Quote Originally Posted by cjblackburn
    Bleach
    Expect a large pile of bottles.
    I just took some of mine into the recycling place from my recent shocking....
    I just told the guy..no. I'm not building a bomb. And I overflowed the bin.
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Ottawa, ON, Canada
    153
    Quote Originally Posted by poolgirl22
    Bleach
    Was is much cheaper than buying $10-20 of shock chemicals from the pool store?
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    I don't really care so much about the cost savings. I care more that I'm doing the right thing in the long run and in control of what goes into my pool...I'm the one who buys mustard and mayo, then mixes them together when I want Dijon mustard, ya know? I am saving money this year for sure, and that to me is a side benefit. Truly, if it cost more and worked better, I wouldn't blink...
    I only use bleach or pool chlorine, regardless of the trips to the recycle place, exclusively because Dichlor shock added CYA I didn't need and only added to my problem of overstabilization. Cal hypo shock bags added calcium which I already have enough of so once I discovered TFP I never looked back. And truly if shocking, even with Dichlor or cal hypo, was being done effectively the way it should be done all along to kill EVERYTHING, then yes the bleach is infinitely cheaper.
    Most people think you throw in the shock bags and you're shocked. Not true. Even if you use the bags you still have to raise the FC it and keep it there until it's all dead.
