Thread: Poor suction when vacuuming?
    Jun 2010
    MI
    36
    When using the 1 ½” hose hooked up to the skimmer this year I noticed that I didn’t seem to be getting the suction I did last season. I first noticed this when I had the vacuum head attached to the hose. I took that off and it still doesn’t seem as powerful as it used to be. There is no blockage in the hose and I did notice that the pressure goes down to about 6psi when the hose is connected to the skimmer and normally it runs at about 15psi. I decided to check the pressure after I noticed a change in the sound of the pump when the hose would be connected. I have only lived in this house with the pool for about 3 years and I had no pool experience before this, so it is possible that this always happened and I just never noticed it before. Is it common for the pressure to drop when you hook up the hose to clean the pool? Is there something else that I am missing? Any input or ideas would be appreciated. Thanks.
    16x32 19,000 gallons vinyl liner IG with vermiculite base, 2 jets, 1 skimmer, 1 floor drain, Hayward s-200 sand filter with Pentair superflo 3/4 HP single speed pump , liquid chlorine.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,166
    Re: Poor suction when vacuuming?
    Are you getting bubbles in the pump basket when vacuuming?
    Is the main drain valve (if there is one) fully open.
    If your hose has a swivel cuff, is it on the vacuum end and not the skimmer end?
    Any chance of a leak in the hose?
    22,468
    It's normal for the filter pressure to drop some when hooking up the vacuum. You've just added a good amount of suction head to the plumbing when you hook the hose up. Not only is it not as large as regular pipe it's corrugated and therefore adds a lot of flow restriction.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Jun 2010
    MI
    36
    Thanks everyone for your input. No air in the pump basket. Hose does not have a swivel cuff and there is no leaks in the hose, I did my best to pressure test it.
    Like I said maybe I am imagining that it used to have better suction. Just thought I would ask if there was something else I could be missing.
    Jun 2010
    San Antonio
    424
    I have always had trouble vacuuming because of low suction. I finally solved the problem. It turns out I had a small piece of plastic in the pump. I mean small. The pump still worked, but it wasn't as strong as it could be. I had to remove the pump basket to reach into the pump and when I did I found the plastic. Put everything back together and now I can vacuum. Don't know if your problem is similar, but you might want to check and make sure there is no debris caught in the pump.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Jun 2010
    MI
    36
    Follow up: I ended up taking the pump basket out and with the pump off I stuck a 4 inch screwdriver in by the impeller and moved it around a bit. I had a bunch of pine needles caked around the impeller. I have to do this every so often now, I can tell when its time based on the way the pump sounds. I basically was just spinning the impeller with the screwdriver and stabbing in there where I could. Make sure there is no possible way the the pump can come on while doing this. Turn off the breaker if you have to.
