Thread: High Phosphates
    Mar 2007
    Ontario, Canada
    294
    High Phosphates
    Just got back from the pool store with a phosphate reading of
    1000.
    my other numbers are
    pH7.9
    FC 4.11
    CC - 0
    TC 4.11
    CYA 35
    alk 100
    hardness 230
    my options are to do nothing, as my water appears clear and no signs of algae. or I could throw in some
    phos out, which involves the pool getting cloudy for 4 days and lots of vacumning etc.
    thoughts?
    skip it! Unless you level is way-super-higher than what was being discussed, someone (waterbear? JasonLion?) has said the high-phos angle is just the latest and greatest way for the pool store to separate your money from your wallet!
    see the last post on this thread.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    gonefishin's Avatar
    Joliet, Il.
    413
    You may want to verify your Ph level. The pool store has it at 7.9 which is a little high...you could use one of the calculator programs to find out how much acid you need to bring it down.
    I think I have the JasonLion calc linked in my signature...check it out>>>
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    30,421
    Combining both posts above is the best advice I think you'll get. Ignore the phos and lower the pH to around 7.4
    Mar 2007
    Ontario, Canada
    294
    Thanks for the advice, I will bring down the pH today, just need to get to the backyard with the acid.
    I do notice that this year my pool is taking a lot more acid than it did last year. Anyways, thanks for the advice. The pool
    store did say I could just leave it alone as nothing may happen, so they are not completely trying to hose me.
