Thread: My pump runs for a second and then short circuits
    What would be causing that?
    TIA
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Do you mean the breaker trips? My guess is you have a GFCI breaker and there is some moisture on a connector or within the pump body. The breakers are common failure items, but moisture is the most common cause of them tripping.
    My recently replace spa pump was doing that after I had it for about a month. The pump had a defect and was replaced.
