Thread: Green Water
    Green Water
    Refilled my above ground pool 24 ft round and 5 foot high. Put a New SWG (Aquatrol), everthing worked great with clear water and then the rain came and the family tured the pump time off.
    Problem: Green Water have added Algea and still green. Went to leslies and got the following results.
    FAC: Low (0)
    TAC: low (0)
    Salt: 3000
    Calcium Hardness: 200
    CYA: Low (0)
    Total Alkalinity: 110
    PH: 7.5
    Lost on what to do, got the SWG so I wouldn't have to buy a bunch of chemicals.
    Any Help would be appreciated.
    18 ft above ground pool
    90 sq. ft cartridge filter
    1 hp pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Green Water
    Welcome to TFP.
    You should probably start by reading these articles:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    Followed by:
    Shocking Your Pool
    and then
    Water Balance for SWCGs
    Pay special attention to the CYA level recommendations. Your SWCG can't keep up with loss from sunlight when your CYA is low.
    It takes a substantial amount of chlorine and persistence to clear it. With the SWCG, you can't shut off the pump for any length of time since you lose your source of chlorine when you do.
    Re: Green Water
    Looks like I will be adding Bleach or Liquid Chorline to get the FC up.
    Do I need to keep the SWG off and run the pump 24 hours.
    1 hp pump
    SW Indiana
    9,199
    Re: Green Water
    You don't HAVE to keep the SWCG off, but it really won't contribute a lot.
    Absolutely run the pump until the water is clear. You can make a significant dent in the green overnight if you stay after it. The reason many people have trouble clearing their pool is that they shock, then wait a day to retest. You want to check it hourly at first, then several times a day until things hold.
