Results 1 to 16 of 16
Thread: Cleaned the pump skimmer basket now it won't turn back on...
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    I cleaned out the pump skimmer basket and now when I turn the filter back on it shuts down while priming and the red "no flow" light on my intellichlor lights up...status of my intelliflo says "cell blocked" on the EasyTouch readout.
    I have taken the lid back off/on 3 times and it still does the same thing. What am I doing wrong??? All was fine until I cleaned the dang basket! Grrrrrrrrr.
    22,000 gal IG Pool & Spa, Fountain and Spa Spillway, Penatair IC-40 SWCG, Pentair Intelliflo Variable Speed Pump, Cartridge, Antigua Blue Wet-Edge
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cleaned the pump skimmer basket now it won't turn back on...
    Valves all back where the should be? Fill the basket housing with water?
    Mar 2007
    Coastalish 'down easter'
    4,160
    I'd suspect a clogged or blocked impeller
    Luv& Luk
    -Ted
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Quote Originally Posted by JohnT
    I didn't move any valves to begin with so I honestly don't know how to tell if they are back "where they should be". I only turned off the pump and emptied the dang basket. It wasn't even that dirty---was just walking by and decided to do it. My bad. Grrr. I tried to fill it back up with water but good grief it was like a losing battle b/c the water level kept going down.
    Clogged impeller? Dear God...I don't even wanna know what that means or what I need to do about it. Let me open a bottle of wine and I'll check back in a bit.
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Update: Went back out and turned pump on. Same thing...red no flow when priming started. While I stood there fretting for a minute, it started to prime again on it's own and the basket filled fully with water. The bubbler on my spa shot up 8 ft high and the pipes started shaking---seriously sounded like a rocket was gonna go off. Just as I go to turn it back off, it settles into "normal mode" and the flow indicator is green and all seems well EXCEPT for the fact that now there are tons of air bubbles coming from the return jets again---so obviously there is air in the pipes.
    30,419
    What's happening is when you open the pump strainer basket, you allow air into the system and you lose "prime". In other words, with the lid off, the water can drain from your pump, filter, etc back through the pipes and into the pool.
    When you turn the pump back on, it is taking the pump a while to reprime as it tries to pull the water from the pool back up to the pump.....that's hard to do for a pump when all it's pumping is air.
    The pipes rattling and such is simply the air being forced through the system back to the pool. Everything you described is perfectly normal for an IG pool.
    What has it been doing prior to this when you cleaned the pump strainer basket? It should've been doing the same thing each time.
    Dallas, TX
    227
    Mine does that when i pull the bottom plug out to drain anything left under the pump basket. I just fill it back up with a garden hose, cap it, and it's good to go when i turn it back on.
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Oh thank you so much!!!! Whew! So the air bubbles in the returns will work themselves out, too?
    In the past it has never stopped priming and turned the intellichlor to "no flow"---it has always fired right back up.
    30,419
    Since this time it behaved differently and all you did was replace the strainer basket lid, then perhaps the lid did not get reseated properly. If air is allowed to get into the lid, the symptoms you describe will show up and it will very likely continue to pull air in through the lid causing some degree of bubbling constantly.
    I would suggest you stop the pump, remove the lid and carfully examine the rubber gasket and make sure it seats nicely on to the pump body. If you get a good seal there, it should reprime as it did before.
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    hey hawkeyes, i think i have a similar set up as you and my PB showed me how to prime the pump by releasing air from the top of the cartridge filter by turning the PSI indicator to the left and pulling up on it and then that releases the air and then once water comes out of the top then i just turn it down into the normal position. that help the pump prime a bit quicker. do you have that ability?
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Quote Originally Posted by ajones02
    Yes! I do have that ability. When exactly do you "turn and pull up"? The minute you turn the pump back on?
    Dumb question: where exactly does that lubricated rubbber circle go? Does it go INSIDE the lid or does it go around the pump where the lid twists on? I remember that coming off when I unscrewed the lid and I bet I didn't get it put back on correctly!!
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    i always turn and pull it up before turning the pump back on. once the pump is turned back on you will hear air escaping from the valve and then as soon as the water starts to shoot out of the top (which means your pump is primed) then you can turn it back down into it's normal mode. the pressure then should begin to read out as it did before.
    the rubber o-ring actually goes inside of the lid. there is a groove that it should fit into. i always clean this groove out and clean the o-ring off and then add some lubricant to the ring before replacing the lid. it will make it easier to to turn the pump cover and get it seated properly.
    make sense?
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Yep....makes total sense. The o-ring came out of that "groove" awhile back but I do think I got it back on correctly based on what you are describing. It may, however, need lubed as I rinsed it off but did not lubricate it. Would lack of lubricant on that ring keep the lid from sealing properly (thus allowing air in)?
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    it would if it was not seated completely against the lid. from my experiences, not adding lubricant everything you remove the lid can stretch the
    o-ring and not allowing the lid to sit tightly around the pump basket. i purchased my lubricant at the local pool store but my guess is you could pick some up at any hardware store. hope that helps!
    22,548
    What tends to happen when you don't lube the o-ring is that during the installation of the lid the dry o-ring grabs the surface and instead of sliding smoothly it wrinkles and causes a crease that can leak.
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Got it!! Will pick up some lube today while out and about and add it to the o-ring tonight. Thank you all so very much!
