Thread: question about intex metal frame pool
    Jun 2007
    MA
    165
    My pool is 1.5 inches off in one small spot is it normal for the poles and top to sway a bit from alot of movement in the pool?
    Cheryl
    14X42 Intex Ultra Frame
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: question about intex metal frame pool
    Sounds normal to me, mine does the same thing.
    I not level by 1" but it gets closer with each passing year.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Aug 2009
    Hattiesburg, MS
    84
    YEP!!! Ours did that when we had one. My daughter who was three at the time thought it was so funny as she called the low spot the deep part. It's normal, but not necessarily a good thing. Keep checking your rails around the pool, in time they may try to shift a bit. In the mean time just have fun with it.
    18x33 Delair Sunsation GS AGP Oval 4 shallow-6 deep mostly buried
