Thread: Walls collapsing while filling - please help me!
    Please help, this pool is ruining my marriage!
    Finally almost done installing a used Hayword 21'x48" AGP. Yesterday we installed the new beaded liner, filled the pool to 1", brushed out the wrinkles and turned of the shop vac as per instructions. It looked beautiful. Today I turned on the hoses and started filling the pool again. I got to about 6" deep and the walls started buckling! I turned off the water. What do I do now? The buckles aren't too bad, but any buckle seems fairly catastrophic.
    Help!
    Tamara
    Re: Walls collapsing while filling - please help me!
    Does the liner fit fairly well? Is it causing the problem?
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Can you post a picture? We've had some people who think their walls are coming in and but they aren't - the liner will stretch in. It REALLY helps to fill the pool on a hot sunny day - that liner will really get soft as butter and stretch so nicely when it's hot and sunny (sun is THE biggest factor - cloudy and warm is not the same)
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I'd be double checking the cove and sand base. If those aren't up to spec, you'll get excess pull on the liner.
    The sand base is perfectly level and the cove is one of those preformed foam things. The liner fit beautifully. I did start filling it yesterday in the morning though. It was about 70 degrees and the sun wasn't hot yet. Dh thinks we should just keep filling and hope the pressure of the water will push out the dents in the wall. I'll wait until it gets hot and sunny to turn on the water today.
