Thread: Pool design-price advice
    Hi Everyone,
    I just got a bid from a reputable company in Central FL (they have been around since 1975.) I have attached the specs, design, etc. Any tips or advice?
    I may drop the water fans....saves me only $125.
    Pool Size: 15.5x28
    Shape:Free Form
    Depth:3'-6'
    STANDARD EQUIPMENT
    Calypso Pebble Pool Finish w/10 Year Full Guarantee
    Pool Circulation Pump
    5 Function Multi-test 1200V Test Kit
    Cantilever Edge Trim
    Pool Filter Package
    8' x 16' telescoping Aluminum Pole
    6" Designer Waterline Tile
    Hayward CL200 Automatic Chlorinator
    Pool Care Video Tape
    3 Shallow end Steps w/ Cap Tile Edges
    8" Main Drains
    Deluxe AB 18" Pool Brush
    Swim-out w/ Rail and Step
    Large Capacity Skimmer
    Aquality Leafnet
    Fibermix Concrete Deck w/ Cool-Deck Topping
    Acrylic Topping
    300w 12V Pool Light
    American Flex a Vec II Vacuum
    Schedule 40 PVC Low Restriction Piping
    Automatic Timer w/ Weatherproof Housing
    Vacuum Hose (30' to 50' as needed)
    Complete 220V hookup as per National Electric Code
    Jobsite Clean-up
    BASE PRICE (Pool w/ standard equipment): $22,388
    Options as Listed Below:
    Aqua Rite Salt $1,000
    Spa Heater
    Cleaning System
    Plumb Vac Line
    Handrail
    Spa Light
    2- Water Fans $125
    Jet Pump
    Alarms or Fence 90' Pool Fence $1,207
    Spillway (
    Total Options $2,332
    Total Price $24,720
    MN
    Re: Pool design-price advice
    Get names and model numbers for every piece of equiptment.
    1- Pool pump name,hp rating, service factor, voltage/amperage and gallon per min. Is it single speed, 2 speed, or a variable speed?
    2- Pool filter package- What type of filter ( DE, Cartridge,or sand ) Name brand, filter area.
    3 - Piping size , pvc or flex, How many skimmers and returns. how many and what size main drain(s).
    4- Lose the test kit if it will yeild 68 bucks and get a tf-100 from here.
    5- Who pays to hual off dirt?
    6- Will the pool be plaster, liner etc? The type of finish should be listed as well as any other info like color.
    7-what type of valving ( jandy or pentair valves, or el cheapo )
    There is more but its all about specification. Have every thing spelled out in writing. Do not accept any verbal agreement. While your pool is not the most expensive I have seen its still a great deal of money, and you are smart to ask questions now.
    Be sure to post on your progress, often there are questions that come up.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
