Results 1 to 7 of 7
Thread: pump humming
    pump humming
    I am hoping that someone here can help me. My hayward 1.5hp pump has been working fine for the last month. Today I went to turn it on and all it wants to do is hum. I checked the plugs, breakers, unplugged to reset and moved the control to recirculate instead of filter (thinking it may be stuck). All it does is hum/buzz. Called hayward and spent 20 mins on hold. Called my local pool dealer and they suggested replacing the pump thinking it was a bearing issue. Any suggestions? I really don't want to spend about $350. TIA
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: pump humming
    Welcome to TFP.
    Sounds like a bad capacitor. Easy and cheap to change.
    Re: pump humming
    Sorry to ask, but my female brain is learning as I go. Where can I get one and is there an online instruction manual for replacing it? I am pretty handy, so I am willing to give it a try.
    22,541
    Re: pump humming
    First thing I'd do is pull the back cover off the pump (turn off breaker first) and take something and try to turn the shaft. Every once in a while we'll hear where the pump sticks for some reason or other and turning the shaft will get it going again. In fact that happened to mine once.
    Re: pump humming
    Thanks, I will try that first.
    Re: pump humming
    Thank you for the input. I actually fixed it by hitting it with a hammer several times to the top and bottom of the motor.
    Here is a video if I can post that.
    http://video.wetheadmedia.com/my-pool-p ... is-humming
    Worked like a charm.
    Aug 2008
    Conway SC
    102
    Re: pump humming
    If it starts working after you do this, I would buy some Non conductive lubricant which is available at home depot electrical section and turn off breaker again and open cover and spray some around the bearings and shaft..
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
